Help Needed With Stress Calculations for Steel & Brass Rods
The discussion revolves around calculating stress and strain for steel and brass rods under tension. For the 14mm diameter steel rod with a 3.08kN load, the calculated stress is 0.02 N/mm². The user seeks guidance on how to determine the rod's extension using the modulus of elasticity, with the relevant formulas provided for stress and strain. Additionally, for a 10mm diameter brass rod that extends 0.3mm under load, the stress is calculated to be 0.17 N/m² using the modulus of elasticity for brass. The importance of unit consistency in calculations is emphasized throughout the conversation.
donkey131
I'm having problem knowing how to work out this question, can anyone point me in the correct direction.
Question
14mm diameter steel rod carries a load of 3.08kN in tension. calculate the stress.?
I ended up with this:
Stress = Force/Area.
Stress = 3.08/154 = Answer = 0.02N/mm²
if the rod is 2.5m long and the modulus of elasticity is 200GN/m2
how much will it extend?
so far i have know idea of the formula or how to work this out?
can anyone help please
I also have one other question related to stress that is
A brass rod measures 10mm in dia, and 150mm length. The rod extends 0.3mm when subjected to a load. given that brass E=85GN/m2
Calculate the stress in the material and the magnitude of the load:
if you could help with the formula that would be a big help.
I'm not able to find any thing on the net and the books i got from the library are over the top in calculations
please help
many thanks
Hi donkey131, welcome to PF. For a rod undergoing axial loading, stress \sigma[/itex] and strain \epsilon[/itex] are related by the equation \sigma=E\epsilon[/itex].<br /> <br /> Make sure to check your units in your calculations.
Another formula that you will need is \epsilon= [l(final)-l(initial)]/l(initial)
so how do i now find the Magnitude.
not sure about this as I am trying to teach my self, it an NVQ course. NOt good teaching your self something you don't know.
Calculate the stress in the material and the magnitude.
10mm = Diameter steel rod
?? = Area of the rod
3.08kN = Tension
?? = Stress
?? = Strain
150mm = Length
0.3mm = Extends
85 GN/m² = Elasticity
Area:
Area = pi x radus² There for: Area = Pi (3.142) x 2.5² (6.25) = 19.637mm² (19.64)
Strain:
Strain = extension (change in Length)/Original Length
Strain = 0.3/150 = 0.002
There for we now can find the Stress:
Stress = Strain x Elasticity
Stress = 0.002 x 85 =0.17N/m²
Answer = 0.17N/m²
so how do i find Magnitude:?
The magnitude is just the absolute value of the number. If the stress is -5 N/m², for example, we describe it as a compressive stress with a magnitude of 5 N/m².
Again, recheck the units in your calculations - I see several errors.
