Help please with the Thevenin Equivalent of this circuit
The discussion focuses on helping a user understand how to find the Thevenin equivalent of a circuit. Participants emphasize the importance of showing prior attempts and understanding basic concepts before seeking help. They suggest removing specific resistors and redrawing the circuit for clarity. The conversation highlights the need for the user to engage actively with the problem and utilize available resources, such as online explanations and videos. Overall, the guidance aims to encourage the user to develop their understanding rather than simply providing answers.
asd852
1.whats the equivalant circuit for circiut shown in figure 3???????
2.how can we determine the Thevenin parameter for question 2?????
mesh/nodal analysis
Likes Delta2
Hi asd852, Welcome to Physics Forums.
We can offer help only after you've shown your own efforts so far. What have you tried?
I am a bit clueless
Likes Delta2
asd852 said:
I am a bit clueless
Then you have taken on a problem that is too advanced for you. Go back and study the basics.
asd852 said:
Homework Statement:: 1.whats the equivalent circuit for circiut shown in figure 3??
Relevant Equations:: mesh/nodal analysis
Seeing that you're new to PF, a bit of help.
For the problem you show (Question 2 with Figure 3):
Consider the circuit with the 9 Ω resistors removed from terminals A and B.
For Question 2: Make a new thread, showing the attachment as full size. Above all, show an attempt and/or be specific about what is confusing to you and what you do know.
There are some good explanations on the web of Thevenin's theorem as well as YouTube videos. I suggest you look into those, try to apply those methods to your problem, and come back here with questions about the confusing bits if you need to. Sometimes you need a different explanation than the one you got in class, or you just need to hear it a few times.
I suspect that part of your problem is that you find this:
part of the circuit confusing. This is a VERY standard exercise in redrawing the circuit and ends up being totally trivial.
Could you please draw an equivalent circiut diagram and calculate the results,after which I assume I would understand my confusing points
Sorry,I find the website you presented irrelevant to the above question
One more try with clues to assist you.
You have probably been told that any points connected by a wire are at the same potential (voltage), at least I hope that was part of your curriculum!
Keeping that in mind, look at the junction between the upper two 9 Ohm resistors.
Can you say what the voltage is there, and why?
If that helped any, pretend the drawing is on a sheet of rubber that you can stretch out of shape. Now mentally drag the common point of the two upper 9 Ohm resistors to a position that makes more visual sense for you.
If you have gotten this far, please post a sketch of the re-arranged circuit.
Cheers,
Tom
(Hang in there asd582, the exercise you were given is designed to be somewhat confusing, and to get that "AH HA" moment in your head when you realize the solution.)
Huh? I did not put a link in my answer. Perhaps you are talking about the link in my signature? That has nothing to do with you. AND you are avoiding my point. DO you find that part of the circuit confusing?
You are not listening:
... show an attempt and/or be specific about what is confusing to you and what you do know.
We're here to HELP you, not do it for you. Drawing an equivalent circuit is the heart of the problem and exactly what YOU need to figure out.
Cheers,
Tom
A picture may help.(two points connected with a viire are the same point in the circuit. )
Which resistors are connected to point A ? And to point B?
Likes Delta2 and SammyS
You get this sort of problem when drawing schematics from PCB traces. My technique was to colour each track, so that wherever it reached, I could see from the colour what it was connected to.
This one is trivially easy, because you use only two colours.
In this case I'd put the A track (red) across the top and B track (blue) along the bottom. Then just put the resistors wherever they'll fit neatly, with their ends connected to the right colour.
Likes Delta2, SammyS and etotheipi
Merlin, that's a good technique but I think we've given hints aplenty with no response from the OP to them. So now, let's wait until he shows some effort in using what we've already provided.
Likes SammyS
