Help Relating Velocity to Force
  • Thread starter Thread starter parkskier
    Force Velocity
To determine the minimum string tension needed to move a 2.7 kg steel block, the static friction must be overcome, calculated as 21.168 N. With a string tension of 26 N, the net force can be used to find the block's acceleration using F=ma. For part B, applying the equation of motion will yield the block's speed after moving 1.0 m under constant acceleration. In part C, the coefficient of friction with oil will reduce the friction force, necessitating a recalculation of acceleration to find the new speed. Understanding these relationships between force, friction, and motion is crucial for solving the problem.
parkskier
A 2.7 kg steel block is at rest on a steel table. A horizontal string pulls on the block.
(a) What is the minimum string tension needed to move the block?
(b) If the string tension is 26 N, what is the block's speed after moving 1.0 m?
(c) If the string tension is 26 N and the table is coated with oil, what is the block's speed after moving 1.0 m?
This is where I really need help. I figured out part A by using F=ma and then using the fact that the coefficient of static friction times the normal force equals the static friction that must be overcome to start movement.
What I need to know is how to get parts C and D...I need an equation to relate velocity to force.
The answer it part A is 21.168 N
No idea on how to get parts B and C
Thanks for any help.
Presumably one has used some coefficient of friction, which is not given in the post, but the approach described is correct.
Now look at the 26 N force compard to the friction force in A (21.168 N).
There is a net force which then accelerates the 2.7 kg mass. a = Fnet/m.
For a constant acceleration, use the appropriate equation of motion to find v at some distance d.
c. What is the coefficient of friction with the oil? Ostensibly that will reduce the friction force, so the apply the approach of part b to get the acceleration.
Thank you much, that helps a lot.
