Calculating Charge and Force of Attraction for Two Charged Coins on a Lab Table
  • Thread starter Thread starter Blink691
The discussion focuses on calculating the charge of two identical charged coins placed 1.35 m apart, each experiencing a force of 2.0 N. The initial approach incorrectly used the force as part of the charge calculation, leading to confusion. Participants clarify that Coulomb's law should be applied correctly, emphasizing that 2.0 N is the force, not the charge. The nature of the force is also debated, with the consensus that like charges repel rather than attract, countering the initial claim of attraction based on weight. Accurate application of the formula and understanding of charge interactions are essential for solving the problem correctly.
Blink691
I did this problem, yet I found out that its wrong because I didn't plug the correct force in. I have no idea what to do now though. If someone can show me what I did wrong and explain it, I would greatly appreciate that. Thank you!
Two coins with identical charges are placed on a lab table 1.35 m apart.
A.If each coin experiences a force of 2.0 N because of the presence of the other coin, calculate the charge on each coin.
FE=KE (q1q2/r^2)
R^2 = 1.35m
q1q2 = 2.0N
FE=KE (2.0N*2.0N)/(1.35^2m)
FE=2.194 or 2.195 A
B.Would the force be classified as a force of attraction or repulsion? Explain your answer.
Force of attraction because it represents a weight.
This question requires a direct application of Coloumb's law (and the assumption that the two coins are like point charges).
Why have you used q1q2 as 2.0N*2.0N? 2 N is the force which each coin experiences, not the charge.
From the information given in the question, you know the values of F , r and that the fact that the two charges are identical. All you need to find is the charge.
Finally, why would the weight decide if the force is attractive or repulsive?
You should know that it is the nature of the charges(ie, like or unlike).
FE=KE (q1q2/r^2)
R^2 = 1.35m
q1q2 = 2.0N
FE=2.194 or 2.195 A
(1) 2.0 N is the force, not the charge! The charge is what you are trying to find.
(2) What happened to the constant Ke? (Look it up.)
Start with Coulomb's law:
F = k q^2/r^2
Rearrange that equation to solve for q in terms of F, k, and r (which are all given or known).
This force has nothing to do with weight (weight is due to mass, not charge). Do like charges attract or repel?
