Help with this network analysis question
The discussion revolves around a network analysis problem involving a source voltage of 120V, a 15-ohm resistor, a dependent source of 2Va, and a 30-ohm resistor. The original poster calculated the current as 2.66A using KVL, but was informed by their teacher that the correct answer is 8A, indicating a possible arithmetic error. Participants confirmed the teacher's solution and discussed the impact of reversing the polarity of the dependent source on the current. Additionally, there were inquiries about strategies for tackling two-port network problems, with suggestions to remember circuit behaviors when shorting or opening ports and to use reference materials for guidance. The conversation highlights common challenges in circuit analysis and the importance of careful calculations.
Pratik77
given:
source voltage =120V
voltage across 15 ohm resistor = Va
there is a dependent source 2Va
and a 30 ohm resistor.
I tried applying KVL i.e 120-30I+2Va-Va=0
where Va=15I
and got I=2.66A
whereas my teacher told me that the answer is 8A. how is it so? Is it some basic knowledge that I have overlooked?
Also as a side note, I have difficulty knowing which theorem to apply in which circuit. I do practise problems but even then I have difficulties especially in chapters like 2-port network. Are there any tips regarding that?
where Va=15I
and got I=2.66A
Show your working. I think you just made an arithmetic error. I used your equations and get 8A.
Umm.. yep you are correct. what would have been the current if the polarity of 2Va was reversed?
Do you have any advice on how to deal with two port network problems. I just don't know how to approach the problems for the asked parameters(z,y,h,etc.)
I made that 1.6A.
Usually it's a matter of remembering if you should short or open circuit a port and then working out the effect of that on the circuit. Perhaps print out some of the slides from here to have as a reference?..
http://www.slideshare.net/PinkyChaudhari/two-port-network
If I've misunderstood perhaps start a new thread with an example.[/quote][/QUOTE]
Likes Pratik77
Thanks!
