How can equations solve moments and equilibrium problems?
The discussion centers on understanding moments and equilibrium in physics problems. The participant struggles with applying the principle of moments, particularly how to set up equations to solve for unknown forces. Key points include the necessity for clockwise and counter-clockwise moments to balance for equilibrium, and the use of torque equations, such as τ = F D_perp and τ = F D sinθ, to find unknowns. Clarifications are provided on how forces create moments about a pivot point, emphasizing that any force not acting through the pivot will exert a torque. The participant gains insight into the relationship between moments and equilibrium, leading to a better grasp of the concepts.
OsiriS^
Hello all. I'm not sure if this is the correct forum because I'm in the UK and I don't know what "Grade K12" is, but the sort of stuff in this forum seems to be the type of work we're doing.
We've just started some work on moments and equilibrium and I'm having difficulty solving the problems. I understand the theory work, such as the principle of moments, requirements for equilibrium and so on, I just need help in understanding why certain things solve the problems. Anyway, all is revealed below :-p
I've had help from the lecturer and so I have the answers but I'm still a little confused...well a lot actually :frown: :blushing:
Here are the two questions:
http://img.photobucket.com/albums/v216/rigdon/questions.jpg
And here are my answers:
http://img.photobucket.com/albums/v216/rigdon/question5.jpg
http://img.photobucket.com/albums/v216/rigdon/question6.jpg
So, for question 5, I understand that Moment = Force x Perpendicular Distance from pivot and that 100N x 3m will give the moment of the weight acting down. But I don't understand how writing the equation 100x3 = Rx8 would allow you to solve R when we are taking points about pivot 'A'. I get it mathematically i.e obviously 100x3 = Rx8 can easily find R, but I mean the moments/equilibrium part of it.
Now for question 6. How does 500x0.4 = T Sin12 x 0.47 allow you to find T? Again I don't mean mathematically, I mean how does it logically work out that that equation can find T...
I know my questions are weird and I would be eternally grateful if someone can make me understand these moments/equilibrium problems.
Thanks in advance :smile:
I'm not sure what you are looking for, but here are a few comments. One of the conditions for equilibrium is that the moments taken about any point must sum to zero. Clockwise and counter-clockwise moments have opposite signs, of course, so another way of expressing the equilibrium condition is: clockwise moments must equal counter-clockwise moments (in magnitude).
One way to find the moment of a force about a point is this. (I'll call the moment by another name, torque.) \tau = F D_{perp}, or the force times the perpendicular distance that the force makes with the pivot point. Clockwise torques = 100x3; counter-clockwise torques = Rx8. So, for equilibrium: 100x3 = Rx8.
The rule above for finding the torque or moment of a force is fine, but there is another mathematically equivalent rule: \tau = F D sin\theta, where D is the distance from the pivot point to where the force is applied, and \theta is the angle between the force vector and the vector drawn from the pivot point to the point where the force is applied. (You should convince yourself that D sin\theta is the same as the perpendicular distance that the force makes with the pivot point.)
Once again, the equilibrium condition is: clockwise moments must equal counter-clockwise moments (in magnitude).
With question 5 I don't understand how the force R creates a moment when the pivot is point A. The part I'm having difficulty with is identifying the clockwise and anti-clockwise moments on the pivot.
Any force exerted at B will exert a torque about A, provided that its line of action does not pass directly through A. The force R, since it points to the left, surely exerts some moment tending to turn the ladder counter-clockwise about point A.
Ah right, now that makes sense. I'll be sure to apply it to the my future moments and equilibrium problems. I suppose if I look at the whole moments thing as a circle, and since the weight of the ladder was already creating a clockwise moment then there would have to be a force acting the other way in order to keep the ladder in equilibrium i.e R.
Thanks :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
