How Deep is the Hole? Solving for Distance Using Kinematics and Speed of Sound
  • Thread starter Thread starter Chiralic
    bodies
A stone dropped into a hole produces a sound that is heard 1.5 seconds later, with the speed of sound in air being 343 m/s. The total time consists of the time the stone takes to fall and the time for the sound to travel back up. To solve for the depth of the hole, the distance traveled by both the stone and the sound must be expressed mathematically. The relationship between the time taken for the stone to fall and the time for the sound to return is crucial, as both cover the same distance. By applying kinematics equations and the speed of sound, the problem can be solved for the hole's depth.
Chiralic
a stone is dropped from rest into a hole. the speed of sound is 343 m/s in air. the sound of the stone striking bottom is heard 1.5s after the stone is dropped, how deep is the hole?
not a clue. I know that in 1.5 s it has to drop, hit bottom, and the sound of it travels at 343 m/s back up to vi.
You're on the right track, just express it mathematically.
Total time = time for stone to fall X meters + time for sound to travel X meters.
(Then you can solve for X.)
Ok, I understand what your saying, but how do I do this with so many missing variables? if 1.5s = dt + dt...but I don't have either d or t for the stone or sound. or can I somehow use: total T = 1/2 at2(squared) + something with speed of sound...Its just on the tip of my brain! or is my logic way off...
Hint: The stone and the sound waves both travel the same distance. For the stone: Use falling body kinematics to express the distance as a function of time (t_1). For the sound waves: Express the distance they travel in terms of the speed of sound and time (t_2).
Now you can put it all together by using these facts:
(1) The distance traveled is the same
(2) t_1 + t_2 is given
Then you can solve for the times and then the distance. Just jump in and try it.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
