How do I solve for the voltage across a and b in this Thevenin circuit problem?
  • Context: Engineering
  • Thread starter Thread starter PenTrik
    Circuit Thevenin
The discussion revolves around solving for the voltage across points a and b in a Thevenin circuit problem involving multiple voltage sources and resistors. Participants explore various methods, including Kirchhoff's Voltage Law (KVL) and Kirchhoff's Current Law (KCL), while addressing the implications of an ideal current source in the circuit.
  • Homework-related
  • One participant initially attempts to apply KVL across the circuit but finds their approach incorrect, suggesting a need for a different method.
  • Another participant proposes that KCL could be applied at a specific node in the circuit, indicating that the voltage at that node is equal to the open circuit voltage (Voc).
  • A later reply points out that the initial KVL equation failed to account for the voltage drop across the current source, which can have any voltage while supplying a constant current.
  • One participant expresses concern about potential inconsistencies in the given values, suggesting that the current demanded by the current source may not match the current through the resistors.
  • Another participant calculates Voc using Ohm's law based on the current through R2 but later revises their calculation after realizing the voltage drop across the current source is non-zero.
  • A subsequent post confirms that the corrected calculation yields a Voc of 13V, acknowledging the previous mistake regarding the current source's voltage drop.
Participants express differing views on the correct approach to the problem, with some proposing KVL and others suggesting KCL. There is no consensus on the initial calculations, and the discussion reflects ongoing uncertainty regarding the implications of the current source.
Participants highlight limitations in their assumptions, particularly regarding the voltage drop across the current source and the consistency of the circuit values. These unresolved aspects contribute to the complexity of the problem.
PenTrik
V1 = 15 V
V2 = 4 V
I = 2 A
R1 = 3 Ohm
R2 = 4 Ohm
R3 = 8 Ohm
R = 2 Ohm
In this part of the question, I have to solve for the voltage across a and b
R isn't listed as a resistor in this circuit because that comes in a later part of the question (which I can do).
KCL and KVL?
My initial thought was to do KVL across the entire circuit. So that means what I did was I had
-V1 - V2 + (R1 + R2) * I
However, this proved to be wrong
Then I tried to do voltage splitting on the resistors. Which means
[R2 / (R1 + R2)] * (V1 + V2)
This is also wrong
How do I do this question?
I guess either KVL or KCL would do if done correctly.
But the current through R1 is I only if there is no current through R3.
Draw in R. I guess it goes between a and b.
You can get he voltage across R2 and generator I is readily.
This gives the current through R1.
Now you can calculate current through R3+R.
The reason that your KVL equation is not working is because it does not account for the voltage drop across the current source. An ideal current source can have any voltage across it and supply a constant current, 2A in this problem.
An more convenient way to solve the problem is to apply KCL at the node connecting V2, R3, and R2. Let's call this node, node A. Since R3 is floating due to the open circuit the voltage at node A is equal to Voc. The current through R1 is given by the following equation:
[tex]\begin{center}I_{R_1}=\frac{V_1-(V_{oc}-V_2)}{R_1}\end{center}[/tex]​
We know this current is equal to the current generated by the current source. Just set the above equation equal to the current source current and solve for Voc.
EDIT: Nevermind. There is no inconsistency below. One of the two answers I got is wrong because I assumed that the voltage drop across the current source was zero. As klouchis has pointed out, this is incorrect. One of my calculations (the second one I did) agrees with his suggested method for finding Voc. So, ignore this first paragraph below:
I think that the given values might be mutually inconsistent (i.e. the current demanded by the current source is not the same as the current demanded by the other branch given the resistors voltage sources present). Here are my arguments:
I think the easiest way to find the open circuit voltage is to take note of two things:
1. The voltage at both ends of R3 is the same, because there is no current across R3. Therefore, if you consider the "node" that is at the other end of R3 (the end opposite to point a), you will see that this "node" must also be at voltage Voc.
2. The voltage at this node can easily be determined by noticing that the branch with R2 must have current I going through it. The current source demands it. It follows from Ohm's law for that branch that:
Voc = IR2 = (2 A)(4 Ω) = 8 V (EDIT: WRONG because the current source has some non-zero voltage drop across it! See method below instead!)
YET, if you look at what the current must be in the other branch (the one with the two voltage sources), you get an inconsistency. KCL would seem to demand that the current in this branch is also I. Ohm's law says that the voltage across R1 is given by the current times the resistance. The voltage across R1 can be calculated as follows. Call the "downstream" side of R1 point 'c.' Then:
Vc + V2 = Voc
OR
Vc = Voc - V2
Ohm's law says:
I = (V1 - Vc)/(R1)
Substituting the expression for Vc:
I = (V1 - Voc + V2)/(R1)
(2 A)(3 Ω) = 15 V - Voc + 4 V
Voc = 15 V + 4 V - 6 V = 13 V.
This is clearly inconsistent with the above answer. (EDIT: That's because the above answer was WRONG).
Cepheid,
Yes, glad you caught your mistake. The correct answer is 13V as you have shown.
Thanks for the help. Yeah, it makes sense now. I was also making the mistake of assuming that the voltage drop across a current source was zero.
  • · Replies 18 ·
  • · Replies 35 ·
