How Do You Calculate Molecules Per Unit Volume from Pressure and Temperature?
To calculate the number of molecules per unit volume (N/V) from given pressure (P) and temperature (T), the ideal gas law PV = NkT can be rearranged to N/V = P/kT. The discussion highlights that with atmospheric pressure and temperature values for Venus and Earth, one can determine that Venus has a denser atmosphere, resulting in a higher N/V ratio compared to Earth. The specific values mentioned are 9.0 x 10^6 Pa and 740 K for Venus, and 1.0 x 10^5 Pa and 320 K for Earth. Ultimately, the calculation of N/V reveals insights into the atmospheric conditions of both planets.
MetalCut
Hi.
Can someone maybe give me an equation to determine the number of molecules per unit volume (N/V) when the pressure(P) and the temperature(T) is given. The pressure is in PA and the temperature is in Kelvin.
Thanx
The ideal gas law says that for an ideal gas: PV=NkT where P, V, and T are pressure (Pascals), volume(m-3), and temperature(K) respectively, N is the number of molecules, and k is Boltzmann's constant of 1.381 × 10−23 J/K
I know that one. But the volume is not given, so how can i get the N/V, the number of molecules per volume?
Can you solve the ideal gas law for N/V?
Yeah, so I must determine the volume first before I can determine the number of molecules. Let me give you the question. Maybe you can point out what I am misssing.
On the sunlit surface of Venus, the atmospheric pressure is 9.0 x 10 6Pa, and the temperature is 740K. On the Earth's surface the atmospheric pressure is 1.0 x 10 5Pa, while the surface temp can reach 320K. These data imply that Venus has a "thicker" atmosphere at its surface than does the earth, which means that the number of molecules per unit volume (N/V) is greater on the surface of Venus than on Earth. Find the ratio (N/V)venus / (N/V)earth.
Thanx
Why do you want to solve for the number of molecules?
You are trying to solve for N/V. Solve for N/V in the ideal gas law and see what it is dependent on.
Ok but isn't N the number of molecules?
Yes, N is the number of molecules, so as dav2008 says, solve for N/V and you will have your answer.
-Hoot:smile:
Ok Thanx man.
