How Do You Calculate the Equation of an Hourglass Curve?
  • Thread starter Thread starter ssj5harsh
    Curve
To calculate the equation of an hourglass curve, the discussion highlights the need for a mathematical representation based on its dimensions, specifically diameter and height. The initial inquiry emphasizes the challenge of determining the curve's equation, with various contributors suggesting complex functions for a 3D representation. Several mathematical functions involving cubic terms are proposed, although their accuracy remains uncertain. The conversation also notes that practical experimentation with sand types and scaling may be necessary to refine the model. Ultimately, a combination of mathematical equations and empirical testing is suggested to achieve the desired hourglass shape.
ssj5harsh
I need to find the equation of the curve of an hourglass. Known: diameter, height. Time taken for the sand to be completely emptied is 1 minute. I would like it if someone would tell me where or how to start. I can't think of anything.
Thanks in advance.
The curve of an hourglass? An hourglass can be many different shapes, starting with a cone. The information you give as "known" has nothing to do with the shape.
i was looking for the same thing today and came across this question
what i came up with was a combination of 8 functions for a 3d representation, although i am not certain if they are correct. also of note is that this is for it laying on its side. anyway, here goes:
x = y3 + z3 + 1, For x, 0 to h
-x = y3 + z3 + 1, For x, -h to 0
-x = -y3 + z3 + 1, For x, -h to 0 (?)
x = -y3 + z3 + 1, For x, 0 to h (?)
x = y3 + z3 - 1, For x, -h to 0
-x = y3 + z3 - 1, For x, 0 to h
-x = -y3 + z3 - 1, For x, 0 to h (?)
x = -y3 + z3 - 1, For x, -h to 0 (?)
where 2h = height of hourglass
from here it (should) should just be a matter of scaling, choosing of sand, and experimental trial and error to come up with the correct amount of the particularly chosen sand.
again, am not sure if this is correct. . . .
Best Regards,
whoops, let's try this again. . . .
f(y,z) = n(y3 + z3) + a; For y = 0, and positive y; For x, 0 to h
f(y,z) = n(-y3 - z3) - a; For negative y; For x, -h to 0
f(y,z) = n(y3 - z3) - a; For negative y; For x, -h to 0
f(y,z) = n(-y3 + z3) + a; For y = 0, and positive y; For x, 0 to h
f(y,z) = n(y3 + z3) - a; For negative y; For x, 0 to h
f(y,z) = n(-y3 - z3) + a; For y = 0, and positive y; For x, -h to 0
f(y,z) = n(y3 - z3) + a; For y = 0, and positive y; For x, -h to 0
f(y,z) = n(-y3 + z3) - a; For negative y; For x, 0 to h
where h = 1/2 hourglass height,
a = the cubed root of the hourglass annulous radius,
and
n = a height to width coefficient
