How Does the Biot-Savart Law Apply to a Wire Shaped in Two Half Circles?
The discussion focuses on applying the Biot-Savart Law to determine the magnetic field and dipole moment of a wire shaped into two half circles connected by straight sections. Participants clarify that the magnetic field at the center is derived from the contributions of the two half-circle loops, with the straight sections contributing zero to the magnetic field. The formula for the magnetic field is expressed as B = (Mu * I) / (2 * R) for each half-circle, leading to a combined expression for the total magnetic field. The integration process using cylindrical coordinates is emphasized for accurate calculations. The overall conclusion is that the magnetic field results from the superposition of the two half-circle contributions.
Kyousik
"A wire is formed into the shape of two half circles connected by equal-length straight sections. A current I flows in the circuit clockwise as shown. Determine (a) The magnitude and the direction of the magnetic field at the center, C, and (b) the magnetic dipole moment of the circuit"
http://img225.imageshack.us/img225/4218/untitled1mm6.jpg
Biot-Savart Law -> dB = (Mu * I * dL) / (4 * Pi * R^2)
The answer is
( Mu * I * [R1 + R2] )/ (4 * R1 * R2)
Not sure how they get it, I'm seeing it as two half circles and you minus them from each other.
B = ( Mu * I * [2 * Pi * R1 / 2] ) / (4 * Pi * R1^2)
B1 = (Mu * I) / (2 * R1)
B2 = (Mu * I) / (2 * R2)
Bt = B1 + B2 ?
Hello,
Do you know the magnetic field in the center of a circle loop with radius a and current i ?
Regards
B = (Mu * I) / (2 * Pi * a); where R = a; I = Ienclosed.
What i know is
B=\frac{\mu_0I}{2a}
The magnetic field in the question is the superposition of contributions of two half-circle loops.
Best regards
This question uses the Biot-Savart Law:
B = \frac{\mu_0 I}{4\pi}\int \frac{d\vec{l} \times \hat{r}}{r^2}
In this case, use cylindrical co-ordinates to find your field for the two radii. For the straight parts, the current is parallel to the r-hat vector, and as such the B-field is zero on those sections. For the two radii:
dl = rd\phi \hat{\phi}; \hat{r} = \hat{s}
Use the cross product and integrate over the angle to get your expression. Do this for the two different radii and add together to give your final magnetic field.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
