How Long Does It Take a Crane to Lift a Load to Maximum Velocity?
To determine the time taken for a crane to lift a 6-tonne load to a maximum velocity of 5 m/s, one must first calculate the acceleration using Newton's second law, given that the crane exerts a force of 3 kN. The discussion highlights the importance of understanding kinematic equations to solve for time. The original poster expresses confusion about the problem's wording and seeks clarification on how to approach it. Participants suggest finding the acceleration and applying kinematic equations to derive the time needed for the load to reach maximum speed. Overall, the conversation emphasizes the need for a solid grasp of basic physics principles to tackle the problem effectively.
tattersfield
hi there, really don't know how to attempt this, could someone please give guidance, thanks. a crane needs a force of 3kN to lift a mass of 6 tonne. if the load is initially at rest and the maximum velocity is 5m/s, determine the time taken to lift the load. Any help would b great, been on with this for 2 days now. thanks
Lift it how far? Or is it the time taken for the crane to accelerate the load to 5m/s?
im not sure, that is the question , just how i got it, i don't understand it at all
Well I'd imagine you have to calculate the time it takes to reach its maximum speed. Do you know of the kinematic equations?
no i am brand new to physics, do you know of a good site that coulld explain it to me? thank you for answering
Ok there are a list of the kinematic equations here:
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
What you'll need to do is find the acceleration of the mass due to the force from the crane using Newtons second law. Once you have the acceleration you can put it into on of the kinematic equations to find the time taken to accelerate to 5m/s.
Like I say before the question isn't posed particularly well so I'm not surprised you're confused. Have a go anyway and if you need more assistance just ask.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
