How to Calculate the Coupled Transfer Function of Two RC-Filters?
To calculate the coupled transfer function of two RC filters, the individual transfer functions H_1(ω) and H_2(ω) can be derived using the impedance model. When coupling the output Uo(1) of the first filter to the input Ui(2) of the second, the resulting transfer function is not simply the product of the two. A more efficient method involves using the node voltage method to analyze the connected nodes Uo1 and Uo2. While there may be tricks to simplify the calculations, the discussion suggests that the node voltage approach is a reliable method. The importance of clear communication and updates in forum discussions is also highlighted.
Galileo
Homework Helper
Suppose you have two RC-filters as shown below. Ignore the #'s, they are for spacing purposes.
o---R1--------o
Ui(1) # # C1 # Uo(1)
o--------------o
o---R2--------o
Ui(2) # # C2 # Uo(2)
o--------------o
Calculating the transfer functions H_1(\omega), H_2(\omega) (H(\omega)=u_o/u_i) using the impedance model is simple.
But what if you couple the two? By coupling the output Uo(1) of the first at the input Ui(2) of the second. Is there an easy way to calculate the resulting transfer function? It's not just the product of the two and my calculation is big and ugly. I know there is a trick or method to do it easily, by using some sort of substitution or something? Can anyone enlighten me?
i'm assuming that your new output is the connected nodes Uo1 and Uo2. in that case i would use the node voltage method for finding the transfer function. concerning a faster way i don't know if there is one.
oh wow i just noticed you post is two years old! haha. you've probably figured it out already.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
