How to find integrals like int (1-x)(x^2-4)dx
  • Thread starter Thread starter amcavoy
    Integrals
To efficiently calculate integrals like ∫(1-x)(x^2-4)dx, the general consensus is to use partial fractions, despite it being a lengthy method. In this specific case, the integral can be simplified by breaking it down into manageable parts, allowing for quicker computation. The first two parts can be evaluated as logarithmic functions, while the last part can also be simplified using recognition of derivatives. Some participants suggest using a graphing calculator like the TI-89 to expedite the process. Overall, mastering partial fractions is essential for tackling similar integrals effectively.
amcavoy
I already know the answer to this, but would like your opinion on the quickest way to calculate integrals like these. I am finding myself evaluating similar integrals in my differential equation homework, and the method that I used (parts and partial fractions) is a mess and takes way too long (if it were to appear on a test).
\int\left(\frac{1-x}{x^2-4}\right)dx
Thanks.
In general, partial fractions is the only way to go. In this particular case, you can split the integral up like this to do it pretty fast:
\int-\frac{x-1}{x^2-4}dx
=-\int\frac{x-2}{(x+2)(x-2)}+\frac{2}{2(x+2)(x-2)}dx
=-\int\frac{1}{x+2}+\frac{2+x}{2(x+2)(x-2)}-\frac{x}{2(x^2-4)}}dx
=-\int\frac{1}{x+2}+\frac{1}{2(x-2)}-\frac{x}{2(x^2-4)}}dx
Now you can directly compute the first two parts as logs and the last as a log by recognizing x as one quarter the derivative of the denomenator
Well it looks like the only way to save time here is to use my TI-89 :smile:.
Thanks for the reply Euler.
