Hydraulic Disassembly Bench (Thesis Project)
The discussion revolves around designing a hydraulic disassembly bench for stripping hydraulic cylinders, specifically focusing on a 10.5" bore cylinder with significant torque requirements for the retaining nut. The project aims to use hydraulic cylinders for rod extraction and a hydraulic motor coupled with a planetary gearbox for nut removal, targeting a torque capacity of around 15,000Nm. Participants express a need for effective methods to handle the high forces involved and to manage oil drainage during the process. There is a mention of using a vise and air impact wrench, but concerns are raised about their adequacy for the required torque. Overall, the conversation seeks expert advice on hydraulic systems to ensure the design is robust and effective.
Gix
Hi Guys and Girls,
I am a final year mech engineering student doing my thesis.
My project is to design a bench and apparatus to "strip" cylinders. This requires the end caps to be removed (or clamps in some cases). The rod to be extracted, sometimes requiring large force, and the piston retaining nut to be removed.
Now I am in the research stage and as a basic idea I have though about using hydraulic cylinders to extract the rod from the barrel. As for the retaining nut I had the idea in my head of coupling a reasonably large hydraulic motor to a planetary reduction.
I am probing for ideas, suggestions or any sort of information if you guys may be of some help. I am new here so apologies if I am expecting too much.
PS> the cylinder I am basing the design around is a 10.5" bore, 1145mm stroke, approx 780kg. The retaining nut is torqued to 8000Nm (plus or minus 800). I want to design for approx 15 000Nm if possible to account for cross threading or overloading (that is ensure bench and motor etc. are capable)
THanks. Sorry about the novel... ha ha.
Welcome to PF, Gix.
I've never disassembled an hydraulic cylinder, so I'm not quite sure what procedures are necessary without seeing some sort of diagram.
Might I assume that this rig does not also have to reassemble the cylinder?
Hi mate thanks for the welcome.
Ideally it will have the capability to re-insert the rod into the barrel.
I can do up a sketch sometime today (keeping in mind I am from aus so time differences ha ha).
I am just chasing some information on the best methods to use hydraulics (motors couple to gearbox, high power cylinders etc.) I need pretty big torque to remove the retaining nut and high power from cylinders to extract the rod.
I will get a sketch done up soon.
Thanks for the help.
Are there any gurus with hydraulics on here (unfortunately our university doesn't teach hydraulics and/or welding :( )
We have a couple. The first that come to mind are Brewnog and Fred Garvin, but there are others as well. Unfortunately, I'm not one of them.
Interestingly enough, I recently have contemplated building something similar to what the OP is describing. However, I can't say I've ever needed anything very complicated to reinstall the piston/ram assembly back into the cylinder bore. Mainly I would want something that catches the remaining oil and drains it out the bottom of a trough and something that is able to pull the piston/ram assembly out of the cylinder bore. A suitable vise can be attached to this rig to hold the ram from turning while a large air impact wrench is used to loosen the nut that holds the piston on the ram. Currently I use a hoist with a hydraulic jack on it to remove the piston/ram from the cylinder bore. I just hook each end with a chain and start pulling. It's a bit messy when it comes apart, hence the reason for wanting a bench/trough to do it.
Yeah mate the trough is in the concept design.
I am mostly concerned with a strong method of extracting the rod from the barrel and the cracking of the retaining nut. I don't think an impact wrench will provide enough torque for this (8000Nm).
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
