Hydraulic Lever: Effect of Force on Pressure
The discussion revolves around the principles of hydraulic systems, specifically focusing on the relationship between force, pressure, and the movement of pistons in a hydraulic lever setup.
  • Participants explore how the application of force on one piston affects the pressure in the fluid and the movement of another piston. Questions are raised about the relationship between different pressures when multiple forces are applied.
Some participants provide insights into the behavior of the pistons and the pressure dynamics, while others express confusion regarding the effects of simultaneous piston movements and the resulting pressure changes. There is an ongoing exploration of how pressures combine in the system.
Participants are discussing the effects of applied forces and the resulting pressures without complete information on the specific parameters of the hydraulic system, such as the areas of the pistons involved.
jarman007
I have a doubt about hydraulic lever
if a force f1 is applied at piston of smaller area a1 then pressure is transmitted to every part of fluid
due to aplication of f1 smaller piston move down and piston at other end move up
does the moving up of second piston have any effect on pressure of liquid
No, the two pistons will move at the same time (or very nearly so), so that the pressure is given by force/area.
If we apply force f1 on one piston and f2 on another such that p1 > p2 and one piston moves down and one up
then what is increase in pressure of liquid
will it be p1 + p2 ??
Yes. It will it be p1 + p2.
thanks a lot
  • · Replies 19 ·
10K
