I need a few formula's- High School Physics on Work/Energy etc
To calculate Work Output, use the formula Work Output = Fg * h. For Work Input, the equation is Work Input = Fa * d. Efficiency can be determined using the formula Efficiency = (Work Output / Work Input) * 100%. Participants emphasize the importance of showing initial thoughts or work to receive assistance. Engaging with class notes is also recommended for better understanding.
nicholz
Hi guys.
I need a few equations to complete a table.
I am given numbers for:
Fg (N)
h (m)
Fa (N)
d(m)
and I need to find:
Work Output (J)
Work Input (J)
Effeciency
If anyone has those three equations I could use it would be greatly appreciated.
Welcome to PF nicholz,
We need some idea of what your talking about first. Secondly, the forum guidelines say that you need to show some working and/or thoughts before we can assists you. So what ideas do you have? Have you looked at your class notes?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
