Ideal Gas Law Application: Finding the Temperature of Air in a Tire
The discussion focuses on applying the Ideal Gas Law to determine the temperature of air in a tire after a change in gauge pressure. The initial conditions include a temperature of 288K and a gauge pressure of 32 psi, which increases to 38 psi after an hour. The correct formula to use is T2 = (P2 + 14.5) * T1 / (P1 + 14.5), leading to a final temperature of 325.5K (52C), correcting the initial miscalculation that resulted in 342K (69C). The importance of using absolute pressure instead of gauge pressure is emphasized.
  • Understanding of the Ideal Gas Law (PV=nRT)
  • Knowledge of gauge pressure versus absolute pressure
  • Familiarity with temperature scales (Kelvin and Celsius)
  • Basic algebra for manipulating equations
  • Study the Ideal Gas Law applications in real-world scenarios
  • Learn about the differences between gauge pressure and absolute pressure
  • Explore temperature conversion between Kelvin and Celsius
  • Practice solving problems involving changes in pressure and temperature
Students studying thermodynamics, physics enthusiasts, and anyone interested in practical applications of the Ideal Gas Law in automotive contexts.
iflabs
[SOLVED] Ideal Gas Law Application
One Sunday morning a family takes an automobile trip to Grandma's. At the start of the trip, the temperature is 288K (15C), and the gauge pressure in the tires is 32lb/in^2 (psi). (The gauge pressure is the excess over 14.5 psi, the exterior air pressure.) After an hour's ride over an interstate highway, the gauge pressure in the tires is 38 psi. What is the temperature of the air in the tires, assuming that air behaves as an ideal gas? Neglect any changes in volume of the tires.
PV=nRT
3. After working around with the universal gas law, the formula I used is: T2=(P2*T1)/P1
T2=(38/32)*288=342K
342-273=69C
The textbook gives the answer 52C. What am I doing wrong? Did I use the wrong units?
They already told you. Gauge pressure is pressure above 14.5 psi. Try solving T2=(38+14.5)*T1/(32+14.5).
Hmmm, I missed that part. What does it mean when the gauge pressure is above 14.5psi?
I forgot, but why can't you use the celsius scale to do the problem?
What they meant is that real pressure=14.5psi+gauge pressure. It's the pressure you would read with a tire gauge, for example. If it reads 0psi that just means that the pressure in the tire is the same as atmospheric pressure. You can't use degrees C because 0C=273K, 1C=274K, but 274/273 is NOT equal to 1/0. You tell me what went wrong.
  • · Replies 17 ·
