Inclination of Meteorids and Craters
  • Thread starter Thread starter theIBnerd
The angle of impact of meteoroids does affect the shape of the craters they create, with low-angle impacts resulting in more elongated craters compared to perpendicular impacts. However, this elongation is significant only for angles less than 15 degrees, while impacts between 45 and 90 degrees show little variation in crater radius. The discussion also highlights the importance of velocity in crater formation, suggesting further investigation into its relationship with crater size. A recommended resource for deeper understanding is "Impact Cratering: a Geological Process" by H.J. Melosh. The conversation emphasizes the complexities of impact dynamics and their effects on crater morphology.
theIBnerd
Hi! I have a quick question: Does the angle of impact (inclination) of meteorids effect the radius of craters they create? If so, does the radius increase as the angle increases? (the angle is between 0 and \frac{\pi}{2})
thank you :)
Astronomy news on Phys.org
Small rocks in space are meteoroids. When they enter the Earth's atmosphere, they are meteors. When they strike the ground, they are meteorites.
Yes, low angle impacts are more elongated than more perpendicular impacts, but these angles are relatively low (<15 degrees). For impacts between 45 and 90 degrees, there is virtually no difference in crater radius.
For more info on the subject, check out "Impact Cratering: a Geological Process" by H.J. Melosh of U. Arizona. This is a top notch book on the subject.
well, thanks a lot! :) that was what i observed during the experiment too. (Although it turned out to be wrongly designed as i couldn't stabilize the velocity at the instance of impact between different angles.)
I guess i will investigate the relation between velocity and crater radius.
anyway, thank you for your reply.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
