Inequalities of negative arguments in complex numbers
The discussion centers on understanding the inequality Arg z ≤ -π/4 in the context of complex numbers. Participants clarify that the approach to arguments is consistent with negative numbers, emphasizing that the solution is an interval rather than a single value. It is noted that 60° is not a valid answer since it is a positive angle, and confusion arises regarding the conversion between radians and degrees. The importance of defining the range for the argument, either in [0, 2π] or [-π, π], is highlighted as crucial for solving the problem correctly. Overall, the conversation aims to clarify how to interpret and solve inequalities involving complex number arguments.
toforfiltum
Arg z≤ -π /4
I'm confused whether the answer to that would be more than -45° or less. Should the approach to arguments be the same as in negative numbers?
toforfiltum said:
Arg z≤ -π /4
3. The Attempt at a Solution [/B]
The problem is the same whether stated in degrees or in radians.
Yes, the approach is the same as for negative numbers.
Regardless of the signs of two numbers, a < b means that b - a is positive.
Likes toforfiltum
Thanks! To confirm, the answer would be 60°...etc?
60° is a positive angle. Do you know how to convert from radians to degrees? Your answer above suggests that you don't.
The answer would not be a single number. It would be an interval of numbers, all of which are less than ##-\pi/4##.
Is it true that 60° ≤ -45° ?
Maybe you are confused with the fact that the argument is defined modulo two pi ?
toforfiltum said:
Arg z≤ -π /4
You need to decide whether you are taking ##\arg \, z ## in ##[0, 2\pi]## in ##[-\pi, \pi]##.
