Insertion Loss / VSWR of RF Lines
  • Thread starter Thread starter prelic
    Lines Loss Rf
Insertion loss in RF transmission lines is frequency-dependent due to variations in input and output impedance, which affect power reflection and transmission. The commonly used formula for insertion loss, IL = 10 * log_10(P_t/P_r), relates transmitted and received power, highlighting the importance of frequency in these measurements. Network analyzers are essential tools for measuring insertion loss across a frequency range, as they send electromagnetic waves and analyze the resulting power ratios. While the characteristic impedance of a transmission line may remain constant, losses increase with frequency due to factors like skin effect and dielectric properties. Understanding these dynamics is crucial for accurate RF design and measurement.
prelic
Hello all,
I'm not sure if any of you have ever used a device that measures RF transmission line loss and presents it as a graph of Insertion Loss (dB) vs. Frequency (GHz), but that is exactly what I'm trying to calculate. I've been looking through equations for days, and I just don't understand how these tools work. The equation I see everywhere for Insertion Loss is IL = 10 * log_10(P_t/P_r) where P_t is the transmitted power before insertion, and P_r is power received after insertion. But if power isn't a function of frequency (only impedance, current, and voltage), then how are they related/calculated? I'm a software engineer, so my knowledge of this kind of this is limited, but I'd really appreciate if someone could help me understand!
Thanks again!
Power is a function of frequency. The input and output impedance of your device is frequency dependent. As such, the reflection of the input power and output power will vary with frequency thus giving you the frequency dependence of the insertion loss. All you network analyzer is doing here is sending in an electromagnetic wave at a known frequency out of it's output port into the device and then it measures the wave that is transmitted out of the device into the input port. The ratio between the transmitted and received power is used to calculate the insertion loss. The analyzer does this over a bandwidth of frequencies to give you the relevant plot.
Are there some general equations that relate power and frequency? I haven't been able to find any useful equations. Thanks again for your help.
I don't know what you're asking for. The insertion loss depends upon the device under test.
Yes that may be so for say an amplifier etc, but in the case of a transmission line as in the OP's query. The transmission line impedance is fixed regardless of the freq its still say 50Ohms at 30MHz or 3GHz. So for a fixed power in and a fixed impedance. The variable is the frequency. As the freq increases so does the insertion loss.
hence we don't need to work out the insertion loss of our favourite coax cables etc, as the manufacturer has already given us those figures over a wide bandwidth
PRELIC...
here is a link to insertion loss measurement methods that may help you :)
http://downloadfile.anritsu.com/Ref...ation-Notes/Application-Note/11410-00276.pdf"
cheers
Dave
PRELIC...
cheers
Dave
A transmission line's impedance is frequency dependent. The characteristic impedance is given as
Z_0 = \sqrt{ \frac{R+j\omega L}{G+j\omega C} }
prelic said:
Hello all,
Thanks again!
Network analyzer is the tool to measure this. Insertion loss almost always is frequency dependent. Even a straight tx line is frequency dependent as series resistance, and parallel conductance all come into play.
I don't quite follow what you want as insetion loss is device dependent. The way we do it is we go through a process to de-embard the input coax line and the output coax line using dummy load to get the s-parameters of the line and back calculate to the input and output of the DUT so you can just look at from the input to the output. This is build into the network analyzer and you just follow the step where they tell you to short the end, open the end and 50 ohm termination. Don't quote the exact step as I have not done it for 7 years. But it is something like this.
I use Microwave Office simulation tool and it has the de-embard feature to get rid of the connecting lines.
Those to me is the difficult part, after that, you just pretty much measure the s-parameters and calculate the insertion loss. De-embarding the lines would be the first step.
If you talk about measuring and find the insertion loss of the DUT, you use 2 port s-parameter. You just follow the 4 steps of of getting the 4 parameters. It is way too long to go into the steps for the devices that's what a RF book is for. You should get an RF book like Micro-Wave Engineering by David Pozar or other ones that talk about network analyzer and measuring s-parameters. This is all dancing on the Smith Chart. Smith Chart is the key of RF design, where you get the s-parameters, input output impedance, forward gain, reflections VSWR... I spent years dancing on the Smith Chart...by inputing a circuit, draw the chart, change values of different components and see how the trace move to adapt the mind to start thinking in Smith Chart, to "see" the trace movement.
so you are saying that all the 50 Ohm coax etc that has ever been produced only works on 1 frequency ? and what is that magic frequency? and that we really need millions different types of transmission lines for every freq that is ever going to be used ??
please explain why my single piece of 50 Ohm coax can support 1MHz to 20GHz ? I don't see any freq dependence :)
Dave
Dave
No, there is a relation between L and C, and the impedance comes out to be constant. It is the characteristic impedance.
If you look at lossless approximation where R and G =0,
Z=\sqrt{\frac L C}
Where U is constant velocity for a given line.
They are related by the speed of propagation...
U=\frac 1 {\sqrt{LC}}
Z=\sqrt{\frac L C}
hi yungman
Yes I understand Zo characteristic impedance, I know my 50 Ohm cable is useable on any freq. but I fail to understand why born2bwired says its freq dependant when it obviously isn't
Dave
maybe there's something else I just haven't realized all these years lol
D
D
You are talking about different things. The characteristic impedance of a standard 50 ohm line is (more or less) independent of frequency as long as you don't start to excite higher order modes in the transmission line, but this is by design ; i.e. the manufacturer have picked the 4 parameters of the cable in such a way that the impedance is more or less constant over a fairly wide BW. But this is a property of specific lines, not a property of transmission lines in general.
Moreover, the losses are of course always frequency dependent.
davenn said:
hi yungman
Dave
It is dependent. If you assume a lossless transmission line then the characteristic impedance is constant. However, once you assume that it is lossy, which has to be if we are to talk about insertion loss, then it is frequency dependent. And yes, they do measure the characteristic impedance at a specific frequency. This frequency, or the bandwidth over which the characteristic impedance is valid, is given to you in the cable specifications. For example, I just randomly pulled off the spec sheet for Belkin's Cat-5 patch cable. Note that for the characteristic impedance they define a variance and a bandwidth over which this is valid.
http://www.belkin.com/cables/pdf/CAT5eUTPPatchA3L791.pdf
More importantly, one needs to remember that a transmission line is a one-dimensional approximation of a three-dimensional waveguide. The TL model does not take into account the nitty-gritty details of wave propagation in a waveguide nor does it appreciate the difference in behavior over a bandwidth between different waveguide structures. But as f95toli points out, manufacturers are aware of this and so they design their cables or waveguides to work over a desired bandwidth so that these dependencies are reduced. To take an extreme example, if you were given a rectangular waveguide, blindless devotion to the TL model would lead one to believe that it could work down to DC when that is most obviously not the case. Transmission line model is just an approximation which is why one needs to perform measurements to get the true behavior of the waveguide or get a more accurate approximation over the bandwidth of interest.
So in my mind there are going to be two factors in insertion loss. There is the inherent loss in the line which will increase with frequency since that increases the electrical length of the line. The second is the variation in the impedances that cause small amounts of reflections.
davenn said:
hi yungman
Dave
The conductance and resistance are frequency dependent, but unless you are talking about very high frequency, it is not important. resistance is from skin effect that it get thinner and thinner as freq goes up. Conductance is from loss tangent of the dielectric. Usually resistance is not a gating factor, you choose the dielectric ( money!) for the frequency you are working with.
In a straight sense, characteristic impedance is frequency dependent and the equation. But I have calculation program that take into all these and they don't vary that much. The lossless approx still pretty much hold.
I forgot to mention. All the de-embardment are just to find the s-parameter of the input feed line and the output line. So the network analyzer take the total measurement as a cascade of three 2 port s-parameters:
1) the input feed line s-parameter.
2) DUT s-parameter.
3) output line s-parameter that hook the DUT back to the network analyzer.
By finding the s-parameter of the two lines, you essentially can eliminate them by calculation so you can measure as if you all directly connect to the DUT and measure the s-parameter. It is all done by the instrument. Good luck on hand calculating the whole thing.
To be honest, most of this thread has gone way over my head. I do appreciate all of your comments, and I have been researching and reading everything I can find on the subject, but my goal is to somehow produce the output of a network analyzer (IL/VSWR vs. Frequency) manually by using characteristics of the setup (cables/connectors/etc). What I got from this thread was that this isn't really possible because IL/VSWR measurements are specific to the actual DUT, and not just specific to identical devices? So if I have 2 independent RF setups that consist of identical components, and then I measure IL/VSWR with a network analyzer, the measurements may not be the same? Is this assumption true?
I don't follow what you said in red.
1) the result is DUT dependent.
2) If you have the same DUT, you should get identical result using different RF setup...IF you properly de-embard the connections. This imply if you use the same analyzer but change to a new set of connecting lines. OR even change the analyzer all together. You just have to go through the pain of calibration, de-embarding.
I afraid if you don't know what we are talking about, it would be very hard if not impossible for you to write the simulation program. To do this, the minimum you need to know are, network parameters, 2-port matrix (linear algebra), s-parameters and how it work. That would be the absolute bare minimum to even attempt to write the program. In reality, you pretty much need to study 2/3the standard RF textbook if not the complete book.
So regardless of my technical knowledge for a minute, if I had a technical document for an RF system that listed the components and specifications like voltage, current, IL limits, etc...could I come up with the output of the network analyzer without having a network analyzer or the actual system?
If you just want to simulate the VSWR and insertion loss of a tx line, not the network analyzer, that is a whole lot easier. Try to simulate the network analyzer is hard. Now you are talking about just the line. If you have the loss tangent of the tx line, you can find the conductance, if you have the dimension of the line and the material of the conductor, you can get the resistance. From that, you can simulate use phasor or other equation. The equation you need to look at is "lossy transmission". It will show you how to find the attenuation constant \alpha\;\hbox{ and phase constant }\;\beta. An Engineering Electromagnetics textbook will have this in detail. The book I recommend is "Field and Wave Electromagnetics" by David K Cheng. If you can limit yourself to parallel plate tx line, coax line, parallel wire tx line like those flat cable used in the old tv antennas. You can actually get the formulas of the attenuation constant or even the whole tx line equation.
Look around first, if I have time, I'll dig up some notes, this is just not a good time as turkey day is tomorrow!:smile:. And at that, it is still not a straight forward equation... more like a collection of equations to find the attenuation constant, phasor calculation, complex numbers. But you just make the whole thing easier now. You can get away without all the s-parameters.
If you can limit to one type of tx line, reply back and let people think about it. Also if the impedance of the source and load is the same as the characteristic impedance of the tx line, it will simplify further. But if you are asking about VSWR, that implies you want to have different impedance.
davenn said:
hi yungman
Dave
Turkey in the oven and I have a little time!
Let's consider a standard tx line model with R' series with L' and then with the shunt capacitance C' parallel with conductance G'. where all are values per unit length. Using solution of differential equation of the voltage and current phasor, we agreed on
Z_0=\sqrt {\frac {R'+j\omega L'}{G'+j\omega C'}}\;\hbox { and we define } \delta = \alpha + j\beta\;=\; \sqrt{(R'+j\omega L')(G'+j\omega C')}\;\Rightarrow Z_0=\frac {R'+j\omega L'} \delta
\delta = \alpha + j\beta\;=\; \sqrt{(R'+j\omega L')(G'+j\omega C')}\;=\; j\omega\sqrt{L'C'}\sqrt{1+\frac{R'}{j\omega L'}}\sqrt{1+\frac {G'}{j\omega C'}}≈j\omega\sqrt{L'C'}\left(1+\frac{R'}{2j\omega L'}\right)\left(1+\frac{G'}{2j\omega C'}\right)\;\hbox { using binomial approx for low loss.}
Expand this out, you'll get:
\delta ≈ j\omega\sqrt{L'C'}\left[1+\frac 1 {2j\omega}\left(\frac {R'}{L'}+\frac{G'}{C'}\right)\right]\;\Rightarrow \alpha =\frac 1 2 \left(R'\sqrt{\frac {C'}{L'}}+G'\sqrt{\frac {L'}{C'}}\right) \;\hbox { and }\;\beta=\omega\sqrt{L'C'}
\hbox { velocity =}v_p=\frac {\omega}{\beta}\;\hbox{ therefore it is independent to R' and G'.}
Z_0=R_0+jX_0 =\frac {R'+j\omega L'} {\delta}≈\sqrt{\frac {L'}{C'}}\left[1+\frac 1 {2j\omega} \left( \frac {R'}{L'}+\frac {G'}{C'}\right) -\frac {R'G'}{4\omega^2L'C'}\right]
\hbox {For low loss, R'G'<< }4\omega^2L'C' \; \Rightarrow \; R_0≈ \frac{L'}{C'} \hbox { and } \;X_0=-\sqrt{\frac{L'}{C'}}\frac 1 {2\omega}\left( \frac {R'}{L'}+\frac {G'}{C'}\right) ≈0
Therefore the characteristic change very little for low loss tx line. We usually don't use high loss tx lines! Excuse me if there is any typo, turkey is calling me, so......
For the op, this might be the place to start.
I'm afraid I'm not sure what you mean by simulating losses of a tx line vs simulating a network analyzer. Basically my system consists of multiple cable assemblies and multiple antennas. What I'd like to do is mock up a graph of insertion loss or VSWR vs frequency for each cable line - antenna path. So basically I'm looking for the simplest way to create a very basic idea of what this graph might look like.
You started out asking to simulate the Network analyzer, That's the reason me and others talked about de-embarding. If you just want to simulate the tx line along, we just look at the tx line alone. Using a Network analyzer imply it has a section of 50Ω line to feed the signal to your tx line, then the other side(output) of the tx line feed into another 50Ω line back to the analyzer.
Do you mean you have many tx lines, every line feeding only one antenna?
If so, you are really talking about a signal generator driving into one end of a tx line, and the other end of that tx line drive into an antenna. Is this what you want to find the insertion loss?
Then you set the generator impedance to 50Ω so the source matched. Then you find the impedance of the antenna at the frequency that you are driving. With that, you complete the circuit. What you have is the tx line with source termination ( generator) at one end and a load termination ( antenna) on the other end. This become very simple.
Confirm that and I can give you the formula using either phasor or simple s-parameter.
This is how I would imagine one to work, and it seems pretty simple. If so, why are network analyzers so expensive?
I believe you are correct. From the document I do have: "each UUT consists of an antenna and associated RF cable". I know the losses are dependent on the DUT, I'm just looking to generate some data with the same basic 'shape' as I might get plugging a network analyzer into each of my 'antenna + RF cable' segments and testing under normal operating conditions.
I am reviewing my notes, just to confirm, I just have to give you a system of a signal generator driving into your DUT( tx line) and the output of the DUT( the other end of the tx line) drive into the antenna.
I just looked up the insertion loss IL=20Log\left( \frac {V_T}{V_R}\right)\;\hbox { where } V_T ,\;V_R\; are just voltage at the load when generator connected to antenna directly and generator to tx line then to antenna respectively.
Confirm this while I read up my notes and hopefully I can give you the equations so you can write the program. It is done in phasor and I hope you understand those...at least to write in programs that consist of complex exponential functions.
We'll see what happen.
It's not clear what you want, still or whether you have grasped the point of Network Analysis. Of course all devices and components will have different characteristics but two adequate quality measuring systems should give the same results when measuring the same device. It would be normal to measure individual stages and the overall system. If you know enough about a device then you can tell what a network analyser will show. There are many different parameters used to characterise devices. The S parameters are particularly suitable for measuring devices which operate at high frequencies when they are incorporated in a system based on 50 Ω transmission lines and the analyser tells you how it will behave under that particular condition. There are other parameters which are better suited to other types of setup but the good thing about S parameters is that it allows a designer to predict the behaviour of a series of devices, linked by 50Ω line.
I think you may be trying to do something that will require a lot more specialised knowledge than you have at present. There isn't a quick way to get into this topic. Better to collaborate with an RF expert if you want to make progress, rather than just ask isolated questions of a forum like this. It is not an efficient way of working professionally.
At this point, sounds like what op is looking for is just the insertion loss when a section of tx line is used to connect from the generator to an antenna with impedance of z_g, \;Z_L\; respectively. If that is the case, it should not be too bad. This is quite standard in RF books to find the phasor relation between the source and the load. I am modifying my notes that is for lossless to lossy transmission line. Then I am going to present it and see whether that help or not. It'll take me a day or two, but it's good for me to review this topics anyway as I have not use it since I left work and it is much more than what the EM books cover.
If you are right in your assumption then, yes, there are plenty of sources of equations to show how the complex impedance is transformed over a length of a transmission line - lossy or lossless. But, as usual, the actual problem has not been made clear. If he had been able to make it clear then he could probably have answered the question himself. Catch 22 again.
Sorry it take me a while to get back because I encounter a malware attack two days ago and I have to fix it...and I am quite suck in computer. So finally I fixed it and spend time in coming up with the equations. In the diagram, V_g \; is the generator, Z_L\; is the antenna. z_g\; is the output impedance of the generator. The transmission line that you want to find the insertion loss is in the middle with impedance of Z_0.
148053[/ATTACH]"]
It is very important to be clear about where is the reference. In this case I follow the SMITH CHART convention where the LOAD( antenna) at z'=0\;. The length towards the generator is z'>0. It is very important to be clear about this as different textbook use different definition and the formulas will be different.
Read back post #20 for the other definitions. I denote generator components using suffix g, and antenna as the load using suffix L. First \Gamma\; is the reflection coeficience and is defined as:
\Gamma_g=\frac{Z_g-Z_0}{Z_g+Z_0}\;,\;\Gamma_L=\frac{Z_L-Z_0}{Z_L+Z_0}\;,\;\Gamma_{IN}=\frac{Z_{IN}-Z_0}{Z_{IN}+Z_0}\;,\;\Gamma_{OUT}=\frac{Z_{OUT}-Z_0}{Z_{OUT}+Z_0}
Where Z_g\;,\; Z_L\;,\;Z_0\; can be complex. \;Z_0\; is usually real. You don't choose a tx line that has complex impedance to make your life miserable! Usually people design so even Z_g\;,\; Z_L\; are real right at the frequency of operation. You'll see if those are real numbers, it can get quite easy.
Hey moderator, please check my work as I don't even trust myelf!
I equate V^+_0\; in term of the generator voltage V_g\; so it is easier to cancel out later:
V^+_0=\frac{V_g e^{\delta l}(1-\Gamma_g)}{2(1-\Gamma_g\Gamma_Le^{-2\delta l})} \;\hbox { and }\;V_L= V^+_0+V^-_0=V^+_0(1+\Gamma_L)=\frac{V_g e^{\delta l}}{2} \frac{(1-\Gamma_g)(1-\Gamma_L)}{(1-\Gamma_g\Gamma_L e^{-2\delta l})}
IL\;\hbox { is insertion loss and }\;IL=10 log \left[\frac {|V_T|^2}{|V_R|^2}\right]\;\hbox { where } V_T= V_L\;\hbox { when }l=0\;\;,\;\;V_R=V_L \hbox { when with tx line length } \;l
\Rightarrow\; V_R=\frac{V_g e^{\delta l}}{2} \frac{(1-\Gamma_g)(1-\Gamma_L)}{(1-\Gamma_g\Gamma_L e^{-2\delta l})}\;\hbox { and }\;V_T=\frac{V_g}{2} \frac{(1-\Gamma_g)(1-\Gamma_L)}{(1-\Gamma_g\Gamma_L)}
|V_T|^2=(V_T)(V_T^*) \;\hbox { where }\;V_T^* \;\hbox { is the complex conjugate of }\;V_T. \;\hbox { and }\;|V_R|^2=(V_R)(V_R^*)
Look at this first and see whether you can understand this. You have to try to get the last part to get the amplitude and it can get tedious. But this is basic complex number calculation and you should know this.
Attached is my notes that give more of the derivations.
BTW don't use McAfee, I have three malware attack on different computers this year! McAfee cannot detect and protect any. I pay for the full feature of virus, firwall and spam, costing me like $70 a year and is absolutely useless. I already change to Norton as of yesterday. The only other thing I change this year is using Firefox instead of Internet Explore. I like Firefox because it do spell check automatically as you already notice my spelling suck also!
  • IL.pdf
    IL.pdf
