How Is the Volume of a Sphere Calculated in Higher Dimensions?
  • Thread starter Thread starter rocket
    Integral Sphere
The volume of a sphere in higher dimensions is defined as V_n(r) = r^n * V_n(1), where V_n(1) represents the volume of the unit sphere. To express B_n(1) in terms of intervals and a lower-dimensional sphere, polar coordinates are utilized, leading to the decomposition B_n(1) = I * J(x) * B_{n-2}(x,y). Fubini's theorem is applied to find V_n(1) in terms of V_{n-2}(1), resulting in V_n(1) = V_{n-2}(1) * integral expressions involving polar coordinates. The discussion highlights the challenge of finding a closed form for V_n(1) solely in terms of n, indicating a need for further exploration of the integral results.
rocket
let B_n(r) = \{x \epsilon R^n| |x| \le r\} be the sphere around the origin of radius r in R^n. let V_n(r) = \int_{B_n(r)} dV be the volume of B_n(r).
a)show that V_n(r) = r^n * V_n(1)
b)write B_n(1) as I*J(x) * B_{n-2}(x,y), where I is a fixed interval for the variable x, J an interval for y dependent on x, and B_{n-2}(x,y) a ball in R^{n-2} with a radius dependent on x and y. this decomposition should allow for use of fubini's theorem in part c)
c)find V_n(1) in terms of V_{n-2}(1)
d)find V_n(1) in terms of only n (eg. find a closed form for V_n(1))
for b), is the answer
B_n(1) = \{I, J \epsilon R^n, B_{n-2}(x,y) \epsilon R^{n-2} | I \epsilon [0,1], J \epsilon [-\sqrt{1-x^2}}, \sqrt{1-x^2}], B_{n-2}(x,y) \epsilon [0,1]*[0,1]*[0,1]\}
not sure about the last part...how do i show that radius of B_{n-2}(x,y) is dependent on x and y?
for c), i found the answer to be V_n(1) = V_{n-2}(1) * \int_{0}^{2 \pi} \int_{0}^{1} r dr d{\theta} (using polar coordinates)
i'm stuck on d). what does it mean by "closed form"
Okay, what have you done on this?
and how do i go about finding it?
a) To show that V_n(r) = r^n * V_n(1), we can use the change of variables formula for integrals. Let x = ry, where y is a vector in R^n. Then, the integral becomes V_n(r) = \int_{B_n(r)} dV = \int_{B_n(1)} \frac{1}{r^n} dV = \frac{1}{r^n} * V_n(1). Therefore, V_n(r) = r^n * V_n(1).
b) To write B_n(1) as I*J(x) * B_{n-2}(x,y), we can use polar coordinates. Let x = (r, \theta, \phi, ..., \psi), where r is the radius and \theta, \phi, ..., \psi are the angles in R^{n-1}. Then, I = [0,1], J(x) = [-\sqrt{1-r^2}, \sqrt{1-r^2}], and B_{n-2}(x,y) = [0,1]^{n-2}. This decomposition allows us to use Fubini's theorem in part c).
c) Using Fubini's theorem, we can express V_n(1) in terms of V_{n-2}(1) as V_n(1) = \int_{B_n(1)} dV = \int_{I} \int_{J(x)} \int_{B_{n-2}(x,y)} dV = \int_{I} \int_{-\sqrt{1-x^2}}^{\sqrt{1-x^2}} \int_{B_{n-2}(x,y)} dV dx dy = \int_{I} \int_{-\sqrt{1-x^2}}^{\sqrt{1-x^2}} V_{n-2}(1) dx dy = V_{n-2}(1) * \int_{I} \int_{-\sqrt{1-x^2}}^{\sqrt{1-x^2}} dx dy = V_{n-2}(1) * \int_{I} 2\sqrt{1-x^2} dx = 2V_{n-2}(1) * \int_{0}^{1} \sqrt{1-x^
