Integrating in polar coordinates (volume)
rhyno89
The solid bounded by the parabolids z = 3x^2 + 3y^2 -7 and z = -x^2 -y^2 + 9
Ok so i set the two z equations into polar form and came up with 3r^2 = 7 and r^2 = 9
I thought that r went from (7/3) ^(1/2) to 3 and that theta went from 0 to 2pi.
I figured the equation to integrate was -4r^2 + 16. (Outer bounds -inner bounds) Anyway, the answer the book gives is different than the two different ways I tried. Just need help setting up the integral...thanks
This is a 3-D problem; you were given z coordinate values in each case. Work with those.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
