Internal Energy of an Expanding Gas
The discussion focuses on calculating the work done, change in internal energy, and heat transfer for a monatomic ideal gas expanding from state A to state B. The work done by the gas is calculated as 3600 J using the formula w = PΔV, where P = 600 N/m² and the change in volume ΔV = 6 m³. The change in internal energy is determined using the first law of thermodynamics, ΔU = W + Q, and the formula U = (3/2)nRT for ideal gases. The participant clarified the distinction between mechanical work and heat, leading to a correct understanding of the problem.
  • Understanding of the first law of thermodynamics
  • Familiarity with ideal gas laws and equations
  • Knowledge of work done by gases during expansion
  • Basic conversion between joules and calories
  • Study the first law of thermodynamics in detail
  • Learn about the properties of monatomic ideal gases
  • Explore the relationship between work, heat, and internal energy
  • Practice problems involving PV diagrams and gas expansions
This discussion is beneficial for students studying thermodynamics, particularly those tackling problems related to ideal gases, as well as educators seeking to clarify concepts of energy transfer in gas systems.
triamanda
2 moles of a monatomic ideal gas expands from state A to state B. PA = PB = 600 N/m2, VA = 3.0 m3 and VB = 9.0 m3.
i. Calculate the work done by the gas as it expands.
ii. Calculate the change in internal energy of the gas as it expands.
iii. Calculate the heat added to or removed from the gas during this expansion.
ΔE = q-w
w = PΔV
PV = nRT
R = 8.314 J/mol*K
i. w = PΔV
w = (600)(9-6) = 3600 J
ii. 4.186 J of work = cal of heat ?
3600/4.186 = 860 cals
I'm having troubles with ii and iii, I'm not sure if the converting of the work into calories is correct. I've looked at all the possible formulas and I'm not sure how to go about finding internal energy with only pressure and volume. Help, please!
Have you come across the formula:
[tex]U = \frac{3}{2}nRT[/tex]​
for an ideal gas? This should be found in any standard textbook.
So you just have to find [tex]U_{2} - U_{1}[/tex] for the change in internal energy.
No, mechanical work is not equal to heat! They are separate concepts. You have to use the first law of thermodynamics
[tex]\Delta U = W + Q[/tex]​
where [tex]\Delta U[/tex] = change in internal energy, W = work done on the gas, Q = heat supplied to the system.
I see that you have already written a variant of the equation under "relevant equations". You just have to use that equation and substitute the relevant values.
Ahhh, I haven't seen that formula!
I've got it now, thank you.
