Solve Internal Resistance Homework Problem
The problem involves a 6.0V battery connected to a parallel combination of a 10 ohm and a 40 ohm resistor, resulting in a total current of 0.25A. The combined resistance of the resistors is calculated to be 8 ohms. Using the equation E = IR + Ir, it is determined that the total resistance (R + r) must equal 24 ohms. While one calculation suggests the internal resistance is 16 ohms, the correct internal resistance is identified as 4 ohms according to the answer book. The discussion highlights the importance of correctly applying the formula to find the internal resistance.
nokia8650
"A 6.0V battery is connected across a parallel combination of two resistors ; one 10 ohm and one 40 ohm. Thee total current provided by the battery is 0.25A. Obtain a value for the internal resistance.
E= IR +Ir
I find the combined resistance of the resistors to be 8 ohms, and sub this into the equation above, and solve for little r, but get an answer of 16 ohms; the correct answer, according to the answer book is 4 ohms. Please can you show me a correct solution to the question!
Thanks
Your answer is correct. Since 6.0 V produces 0.25 A of current, R+r must be 24 ohms.
10 and 40 ohms parallel is indeed 8 ohms, so r must be 16 ohms.
