Internal vector symmetry of Dirac Lagrangian
gu1t4r5
Find the conserved Noether current j^\mu of the Dirac Lagrangian
L = \bar{\psi} ( i \partial_\mu \gamma^\mu - m ) \psi
under the transformation:
\psi \rightarrow e^{i \alpha} \psi \,\,\,\,\,\,\,\,\,\, \bar{\psi} \rightarrow e^{-i \alpha} \bar{\psi}
j^\mu = \frac{\partial L}{\partial(\partial_\mu \psi)} \Delta \psi + \frac{\partial L}{\partial(\partial_\mu \bar{\psi})} \Delta \bar{\psi} - J^\mu
Substituting the transformations into the langrangian shows it's invariant, so J^\mu = 0.
For infinitesimal \alpha , \Delta \psi = i \alpha \psi \,\,\,\,\,\,\,\, \Delta \bar{\psi} = -i \alpha \bar{\psi} .
The conserved current then becomes:
j^\mu = \bar{\psi} i \gamma^\mu . i \alpha \psi = - \alpha \bar{\psi} \gamma^\mu \psi
Whenever I have seen this result states however, the - \alpha seems to have been dropped. The derivative of my result will still be zero (so my derived current is conserved as it should be) but I cannot see why the result is usually quoted as
j^\mu = \bar{\psi} \gamma^\mu \psi
Has this multiplicative constant simply been dropped as it is irrelevant to the conservation, or am I missing something else?
Thanks.
gu1t4r5 said:
Has this multiplicative constant simply been dropped as it is irrelevant to the conservation?
Yes. The normal thing is to define the current as the derivative of your expression with respect to ##\alpha##.
Thanks for the reply. I'm a little confused though sorry, do you mean j^\mu is usually defined as it's derivative w.r.t the multiplicative constant ( ie, w.r.t - \alpha here ), as the derivative w.r.t. \alpha would make make j^\mu = - \bar{\psi} \gamma^\mu \psi (ie, still out by a negative)
You can always multiply by a constant and still have a conserved current. I could also define a transformation which is using ##e^{2\alpha}##, but of course this does not correspond to any other physics.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
