Assessing Consistency of Experimental Data: Comparing Two Values of k
  • Thread starter Thread starter FishareFriend
    Data
The discussion focuses on assessing the consistency of two experimental values for k, calculated as κ1: 0.0607±0.002 Nm and κ2: 0.0564±0.008 Nm. The individual ranges of the values indicate that κ1 is entirely within the range of κ2, suggesting a high level of consistency. Statistical methods for further analysis are mentioned but not elaborated upon, indicating a need for deeper understanding in that area. Overall, the results appear to support the conclusion of consistency between the two values. This analysis highlights the importance of error margins in evaluating experimental data consistency.
FishareFriend
Is my data consistent??
I've obtained two values for k from two different experimental methods and have calculated errors for each and now I want to comment on their consistency with one another. However I'm not too sure how to go about doing that, have a feeling there's some way with statistics but I'm still very new to that so am still not entirely sure how it all works. My results are given below. Thanks
κ1: 0.0607±0.002 Nm
κ2: 0.0564±0.008 Nm
They look highly consistent to me. They don't just overlap; the K1 range is entirely encompassed by the K2 range.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
