Is static frinction a conservative force?
The discussion centers on the nature of static friction and its classification as a conservative force in the context of a system involving two blocks and a spring. Participants assert that static friction does not dissipate energy, unlike kinetic friction, which is definitively non-conservative. The potential energy of the upper block cannot be calculated solely based on static friction, as it primarily relates to the spring's displacement. The conclusion drawn is that static friction facilitates motion without energy loss, but does not directly contribute to potential energy calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of conservative and non-conservative forces
  • Knowledge of potential energy and its relation to mechanical systems
  • Basic principles of spring mechanics, including Hooke's Law
  • Research the characteristics of conservative vs. non-conservative forces in physics
  • Study the principles of potential energy in mechanical systems
  • Explore Hooke's Law and its applications in spring mechanics
  • Investigate the role of friction in energy transfer within physical systems
Students of physics, educators teaching mechanics, and anyone interested in the dynamics of forces and energy in mechanical systems.
Stergios
Suppose we have a two blocks of masses m1 and m2, one on the top of another. The lower block is attached to a spring which is attached to the wall. These two blocks are on a zero-friction floor. We give the lower block a velocity so that the upper block is not sliding on the lower one. Considering known m1, m2 and spring constant k, can we calculate the potential energy of the upper block as a function of the displacement from the rest point?
I don't think that we can calculate a potential energy of the upper block as the upper body is moving by the static friction. If static friction is a conservative force we can calculate it. If not, this question is meaningless.
Hi Stergios. Kinetic friction is non conservative because it dissipates energy as heat from the system to the surrounding. So does static friction dissipate any energy from the system and to the surroundings?
Static friction is the moving force of the top block. Potential energy is being stored in the spring, which is attached to the bottom block. Can we tell that static friction is connected with a potential energy?
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 17 ·
