Is There a Solution to This Tricky Integral? 1/(xe^x)
  • Thread starter Thread starter S.N.
    Integral
S.N.
Find the integral of
1/(xe^x)
None really... integration by parts maybe: integral of udv = vu - integral of vdu
I tried this by parts but didn't really get anywhere, it definitely doesn't simplify into anything useful. It's the solution to an ODE so maybe there's a type in my book, because I always get this as the final integral I have to compute.
Maybe that is the final answer to your question, it's an integral.
What was the ODE?
If you want an analytic answer, you'll need to use the Exponential Integral function Ei(x), defined to be the integral from 0 to x of e^(t)/t dt.
EDIT: This can be written as Ei(x) = \int_0^x \frac{e^t}{t} dt
great, thank you
I think it would actually be an 'incomplete gamma function', since the e^t is in the denominator.
Actually, if you write this as e^(-t)/t, and then substitute u=-t, du=-dt, you get this:
\int - \frac{e^u}{u} du
And the solution follows.
True. The incomplete gamma of degree 0 is basically the same as the Ei. You can represent it either way. Sorry.
