Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #1,751
blab31 said:
in this document (http://www.nisa.meti.go.jp/english/files/en20110327-1-5.pdf ) i understand there has been mistakes about I-134 and possibly other elements. But even without these I-134 and Co-56 numbers, something troubles me.
As i understand, they can only measure up to 1 sieverts with current equipment there (press reports worldwide are 1 sieverts per hour but original documents show MORE than 1 sievert per hour without more details. In this pdf, measurements inside Unit 3 are at 750 msv/h).
Knowing that for example :
I-131 - Unit 2 : 1.3×10E7 vs Unit 3 : 3.2×10E5
Cs-137 - Unit 2 : 2.3×10E6 vs Unit 3 : 5.6×10E4
the list goes on, but from what i see most elements are about 50 times higher in Unit 2 compared to Unit 3.
My question is : is there a way to calculate (approximately) the real number of Sv/h in Unit 2 (and outside Unit 2 probably now...), as we know Unit 3 water surface is at 750 msv/h ?
When the activity of the water is 50 times higher, the dose rate above the water is also 50 times higher, because it is the same brew of isotopes. Edit: assuming equal depth.
So yes, the dose rate in the turbine hall of unit 2 is about 30 sievert per hour.
Which makes it impossible to do work there.
  • #1,752
Activity in the contaminated water has been specified as sieverts per hour AT THE SURFACE. Would the absorbed dose be greater under the surface, as with a worker standing in the contaminated water?
  • #1,753
Clever move to report >1000mSv , with 30Sv confirmed the exodus starts
Now considering the large area, what would the the radiation be say on the floor above?
or is 30cm to 40cm of concrete floor slab be sufficient shield?
  • #1,754
EDF announced a set of relief measures March 18, including the dispatch of experts and robots to the Fukushima plant in the wake of radiation leaks following a magnitude-9.0 earthquake and tsunami. But a media officer for Besson said the package is separate from TEPCO's request for support.
I want to mention that since the very beginning, TEPCO as refused any help from american experts, then refused the proposal of AREVA/EDF to send robots from France, and also refused help from IAEA (IAEA receives report from NISA which gets information from TEPCO as TEPCO is THE only source of information for what happens in the plant). Now it is confirmed that TEPCO is asking help from France.
These are facts. But they may lead to political conclusions... which i won't draw!
Ouchhhhhh...
thanks for the clarification!
But I see in many articles written that the radiation is 1 Sievert/h in turbine building 2, which i interpret then as a mistake from a misleading info if I understand well: is it that difficult to have instruments measuring more than 1 sievert/h? Again that's unbelievable so see how information is biased because of inaccuracies and again misleading infos from TEPCO... Saying it's "more than 1 Sievert/h" when it's probably 30 Sievert/h is a misleading way (as a minimum!) of saying things, don't you think?
  • #1,755
France, offered a week ago a few robots design to operate when men could not, Tepco or Japan , politely declined judging they were not necessary at the time. They likely reconsidered
(As far as we know Tepco did not refuse the 100t of boric acid, 3000 mask , 10 000 radiation suit, 20 000 Glove sent by Areva / EDF on the 17/18th)
  • #1,756
AntonL said:
That seems to be correct, steam coming from the transfer chute area, what are the implication for the containment - TCups that drawing of yours with orange flame marks seems very plausible.
As for the condition of the fuel in SFP with heavy stuff dropping in we can only speculate, An explosive shockwave followed by a crane falling into the pool, could that have "Tsunamied" a bundle of fuel rods out of the pool, that we speculated to have observed in other photos?
Below image of crane in block 4 for comparison, seems to gone missing in block 3
and for block 1 we can see in the video the roof wrapped around the crane
I believe the image is from - http://www.youtube.com/modchannel/?gl=JP&hl=ja
11-03-27 (March 27, 2011) 10:11:06 (video 2:32 / 4:21)
It seems similar to the screen shot I took.
I expect that the refueling or fuel handling machine is parked over or at the end of the spent fuel pool.
There is another shot of a yellow cap, which is probably the drywell head/cap of unit 4.
I would expect that the dry well cap is on the opposite end of the building from the spent fuel pool.
  • #1,757
@Astronuc -
Yes. Just so we are on the same page --
The drywell cap and fuel handling machine in the screen shots you referenced are from unit 4, where,
1) the explosion appeared less intense than in unit 3, and
2) the fuel rods had been taken out of the reactor core 4 and put in the SFP 4
3) the fuel handling machine from unit 4 has been visible on all previous videos, I believe.
The annotated photo with the proposed location of the fuel handling machine actually in the SFP is from unit 3. The suggestion that the fuel handling machine is actually in the pool came from the reference in the initial post #1760
https://www.physicsforums.com/showpost.php?p=3215310&postcount=1760
To Recap
The venting steam is coming (or initially came) from unit 3, in an area where I suggest there may have been damage to the chute and gate forming part of the primary containment for RV3. I postulate that had the water level in SFP 3 been low, then there would have been no water behind the gate and that the loss of hydrostatic pressure behind the gate, plus possible compromise of the pneumatic seals of the gate, plus one hell of an explosion, may have damaged the primary containment at the location of the gate, whether the hydrogen explosion originated from within the drywall containment or from the top floor of the building.
The reinforced concrete weight bearing columns, east and west, coupled to the large rails for the overhead crane tended to hold the sidewalls together, such that the main force of the explosion (actually in both units 3 and 4) seem to have blown out the north-south walls and the roof.
In unit 3, the north wall weight bearing columns actually collapsed and the overhead crane ended up atop an adjacent building below on the north side of bldg 3.
  • #1,759
AntonL said:
We discussed a view days back about international teams working hard to help solve this problem.
Only today it is confirmed that Tepco is seeking actively help, a bit late it seems
It doesn't state when they asked for help.
  • #1,760
about Japan Earthquake: nuclear plants , Meti just reported today http://www.meti.go.jp/press/20110328007/20110328007.pdf
level 0 INES event at the Toukai power plant, The concentration of radioactive materials released was less than 1 in 4,000 of legal threshold
  • #1,761
Ah What, 3000 mask, 10 000 radiation suite etc...
That's anticipation or (pre)-planning for a really bad event...
I'm feeling more than just a little political at the moment...
  • #1,763
Who can confirm or dismiss this calculation?
It is a serious turning point we're looking at - and it will be very interesting to get a second opinion,
  • #1,764
|Fred said:
Yes those sample were taken on the 22 and the 23 only released today (2 hours ago)and journalist were pissed.. same for the trench with water they were tested yesterday and they only released info today..
Again as explained if you watch those Press Conference on the right inside you have a social chat and the journalist upload the document as soon as they are handled... its media 2.0 if you like.
The samples (pressurized and non-pressurized) need to be prepped to allow counting (reduce volume on high activity samples), counted several times, along with decay of high activity short lived radionuclides so the spectrum is cleaned up. Detectors can only absorb so much radiation, so samples need to be diluted or counted from a distance.
I still want to know if the upgrades to the post accident reactor coolant sampling system, performed as designed (NRC NUREG - 0737, Post TMI Action Item II.B.3). Some plants spent hundreds of thousands (some cases over a million) of dollars on these systems. I, as many, considered that the complexity of the systems would only allow it to be use once (even at that) and then buried under a pile of lead. All systems required an in-line filter (within the reactor compartment) to screen out large particles/chunks so the system's small diameter piping and pipetting apparatus would not clog up.
  • #1,765
It is a good chance that most of the protective clothing France' sent will not properly fit the Japanese person.
  • #1,766
Fukushima trenches news coverage:
High level radiation now in trenches outside Tubine building.
  • #1,767
NEI: UPDATE AS OF 1:30 P.M. EDT, MONDAY, MARCH 28:
Tokyo Electric Power Co. has detected isolated, low concentrations of plutonium in the soil at the Fukushima Daiichi nuclear power station. The density of plutonium is equivalent to the fallout that reached Japan from nuclear weapons testing during the Cold War, the company said.
TEPCO conducted analysis of plutonium contained in the soil collected on March 21 and 22 at five locations at the Fukushima Daiichi plant. Plutonium 238, 239 and 240 were detected, however just two of the samples may be the direct result of the recent incident, considering the ratio of the plutonium isotopes.
"The density detected in the plutonium is equivalent to the density in the soil under normal environmental conditions and therefore poses no major impact on human health," TEPCO said. The company said it plans to strengthen environmental monitoring inside the station and surrounding areas.
  • #1,768
jlduh said:
...But I see in many articles written that the radiation is 1 Sievert/h in turbine building 2, which i interpret then as a mistake from a misleading info if I understand well: is it that difficult to have instruments measuring more than 1 sievert/h?
A properly designed radiation measuring instrument can easily measure 30 Sieverts per hour with little saturation or nonlinearity.
1 Sievert = 1 joule (of energy deposition) per Kg = 0.001 joules per gram
1 Sv/hr = 280 x 10-9 joules per gram-sec
Because it takes about 35 eV to create an electron-ion pair in nitrogen (for example), the current in an ionization chamber would be about
1 Sv/hr = 7.9 nanoamps per gram of nitrogen gas (or air). 1 liter of air at STP is about 1.29 grams.
So 30 Sv/hr = 310 nanoamps per liter of gas in the ionization chamber.
For high dose rates, the ion chamber must be properly designed to minimize the effects of space charge (in the gas) on the electric fields in the chamber, which can affect the charge collection efficiency.
Radiation levels of this order are often seen around particle accelerators. The radiation detectors are designed to measure over 1 Sv/second. See
http://ab-div-bdi-bl-blm.web.cern.c...ectors/Literature/schaefer_biw02_tutorial.pdf
Bob S
  • #1,769
New poster here.. I've been following this thread since last saturday with great interest (and varying levels of understanding).
I have a couple questions (hopefully reasonably intelligent ones).
Regarding the contaminated water in the containment basement(s);
I'm not fully understanding the nature of the radioactive contamination; is it radioactive isotopes dissolved in the water, or is it more likely particulates in suspension?
I've been wondering if some of the sea water filtration type equipment that desalinates sea water might be an effective "trap" to help decontaminate some of the water that's accumulating, or if filtration would be ineffective on dissolved elements?
Second;
Regarding the "long term" containment at the Fukushima site, after the more critical short-term stabilization and clean up occurs...
I know there's a lot we DON'T know yet, that we'll need to know more about before a "long term" plan can be developed, but in broad terms; How will the site most likely be managed in the 5 to 50 years in the future time frame?
Is it likely that Units 1, 2, and 3 will be walled up in an enormous sarcophagus building, to be dissassembled over the next 40 years?
Or (again, pending more information coming out about the states of the RPV and Containment), is it likely that substantial clean-up and removal of spent fuel in the SFP's will likely be able to happen without a giant tomb being built?
Thanks to everyone again for an outstanding, calm, rational discussion without the hype and hyperbole that the "news" talking heads have been giving.
Paul F.
  • #1,770
Good evening!
Plutonium appears after an explosion on 3 reactor scattered?
  • #1,771
The results can be found on the TEPCO report:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110328e14.pdf
At sampling spots 1 and 5 the ratio of Pu-238 to total Pu activity is of the order of 1..2, which means the Pu originates from fuel with burnups > 10 MWd/kgU, i.e. reactor fuel. So, even though the absolute value of the Pu activity is not significantly higher than that resulting from the atmospheric nuclear testing, its composition implies that some fuel damages have occurred in such a way that small amounts of fuel have been dispersed to the vicinity of the plant.
The locations of the sampling spots are shown there:
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110328e15.pdf
  • #1,772
I've been wondering about the backup generators that were flown in that had "plugs which could not be used"...
I wonder if, since part of Japan uses 50hz power, and another part uses 60hz, if it was actually a mis-match of equipment phase, rather than the physical "plug" that was mismatched?
A poor translation, perhaps?
Paul F.
  • #1,773
jlduh said:
Pietkuip, you said: "30 sievert/hour"
Ouchhhhhh...
This failure in reporting is the incompetence of journalists and "experts", at NHK and other places. Some of them get it right, though. For example this guy: http://yokosonews.com/live/ He reported accurately that the true dose rate might be several times higher. And he seems to be mainly a culture and entertainment reporter. It seems that he had his info straight from watching a Tepco press conference.
No, it is not difficult to measure higher dose rates, see a previous posting. But the workers do not carry such instruments.
I must modify my estimate a bit with a caveat: I was tacitly assuming equal depths of the water in buildings 2 and 3. Dose rates will be higher if the water is deeper, up to the screening length for gammas.
  • #1,774
Bob S
Areas around particle accelerators are enviornmentally stable. Only post TMI reactor compartment (dry well and reactor building) gamma detectors are designed and hardened for ultra-high dose rate measurements (10^5 Sv/hr) in a degraded environment. The equipment I am referring to is off the shelf laboratory type detectors.
  • #1,775
Here are a couple of radiation mapping sites for Japan. The last one is the organization that makes them possible. They are probably more of interest from an academic standpoint of examining spontaneous self-help networks since the calibration would be difficult to establish. But since they monitor radiation I thought they might be of interest, if not use, here.
Liam
http://japan.failedrobot.com/
http://www.rdtn.org/
http://community.pachube.com/node/611
  • #1,776
That is the core of the reactor?
  • #1,777
Could someone comment on the existence of Plutonium that has now been confirmed in the soil - does this make the current radius around the plant likely to change? What is the possibility of Plutonium spreading through the air and water to destinations further out of the zone (80km US has deliniated?)?
I`ve read that Plutonium is heavy and does not penetrate paper, but is exteeme if inhaled. Thanks
  • #1,778
|Fred said:
According to the same article those 20 to 50% might as well be 10% when the French do the math. (assuming it's math they are doing)
Any how , make your mind by your self !
I'll leave it to you to judge of the merit of the claim (speculation really) from the Austrian Weather channel http://www.zamg.ac.at (that's the expert)
(and may be blame the journalist...)
This data is not from the 'weather channel', are you intentionally trying to discredit the report?
The New Scientists reports on the same information:
http://www.newscientist.com/article...dioactive-fallout-nears-chernobyl-levels.html
  • #1,779
My Nephew, who was living in Tokyo and is now coming home:
http://www.chugai-pharm.co.jp/hc/Satellite?c=CrpCorner_C&cid=1259593215924&pagename=Chugai%2FCrpClassification
Just thought I'd try to remind people that this is also a human issue. It affects all of us. Our judgment, our empirical approach, our perceived knowledge and our humanity. I guess there are some things we can't be empirical about.
  • #1,780
I would be more interested in the How that in the from where, and would appreciate if someone could speculate on how Pu could make his way to the location it was found?
  • #1,781
From a "dirty boom" at unit 3?
  • #1,782
It is possible.
The longer this is going on the less I am trusting TEPCO. It appears that they have a history of lying and fudging data. And the Japanese government is asking them to provide more information. Well at least it is not begging.
See for instance:
http://online.wsj.com/article/SB10001424052748703363904576200533746195522.html
"In 2007, an earthquake heavily damaged Tepco's Kashiwazaki-Kariwa plant. The company initially said there was no release of radiation, but admitted later that the quake released radiation and spilled radioactive water into the Sea of Japan."
"In Japan in 1999, an uncontrolled nuclear chain reaction at a uranium-reprocessing plant killed two employees and spewed radioactive neutrons over the countryside. Government officials later said safety equipment at the plant was missing and the people involved lacked training, adding that their assessment of the accident's seriousness was "inadequate.""
"..The scandal was the latest in a string of nuclear safety records cover-ups by Tepco, including the revelation that the company's doctoring of safety records concerning reactor shrouds, a part of the reactors themselves, in the 1980s through the early 1990s. Five top executives resigned after the company admitted to having falsified safety."
"In 2003, Tepco shut down all of its nuclear reactors for inspections, acknowledging the systematic cover-up of inspection data showing cracks in reactors. "
"The Fukushima Daiichi plant has a black mark on its record from earlier in the last decade, when a scandal involving falsified safety records led to parent company Tepco briefly shutting down its entire nuclear fleet in Japan. In 2002, Tepco admitted to the Nuclear and Industrial Safety Agency that it had falsified the results of safety tests on the containment vessel of the No. 1 reactor, which is now one of three reactors that workers are struggling to keep from overheating. The test took place in 1991-1992. "
http://nuclear-news.net/2011/03/22/tokyo-electric-power-company-tepco-faked-nuclear-safety-records/
"The operator of the Fukushima No. 1 plant submitted a report to the country’s nuclear watchdog 10 days before the quake hit on March 11, admitting it had failed to inspect 33 pieces of equipment in its six reactors."
"A power board distributing electricity to a reactor’s temperature control valves was not examined for 11 years, and inspectors faked records, pretending to make thorough inspections when in fact they were only cursory, Tepco said."
  • #1,784
Astronuc said:
If the fuel grains wash out, they go with the flow. If there is no flow, then they would settle toward the bottom of the core, or down through the plenum under the core plate.
Now, with the seawater, I have to wonder if some of the fuel particles will actually dissolve, in which one then has a solution, e.g., uranyl chloride. I don't know of any research into the chemical behavior of spent fuel in seawater.
The best source I could find for seawater interactions of fission products was related to the dissolution of Plutonium Dioxide in radioisotope power generators used in space exploration:
http://www.osti.gov/bridge/servlets/purl/4839392-lrKndC/4839392.pdf
Basically, the microspheres they tested did not dissolve very well into sea water (about 0.012 - 0.016 μg/mg/day - p19) and (this isn't relevant yet, but if PuO2 were released into the open ocean it's a good thing) if they are encrusted with marine growth their dissolution rates go down by about half (about 0.0048 - 0.0076 μg/mg/day - p19.)
This obviously doesn't take into account the presence of other compounds in close proximity that might chemically interact with the Pu.
  • #1,785
How many pounds or tons of fuel rods in 1 of these types of working reactors then *3/50% (conservatively speaking) for a possible amount of radioactive lava?
  • #1,786
This may well be a naive reaction, but it seems to me that the obvious thing to do with the radioactively contaminated water in the turbine buildings is to pump it back into the reactors. Is there something wrong with that action? If/when they are able to re-establish core cooling, perhaps they could then work on dealing with the water contamination (salt, radioactive elements, etc) and leaks. But until then, why not reuse this water for the evaporative cooling?
  • #1,787
Trench dimensions:
3x4x76 meters.
Source: http://www3.nhk.or.jp/daily/english/28_h37.html
3x4x76 = 912 m3.
Lets say 70% is full of water = 638 m3 of water. That is a lot of water...
I would like to learn:
1. Did it fill up from the Tsunami wave? Plausible.
2. When did last time inspect it - i.e. has it been dry after the Tsunami hit?
3. The article above talks about "a poodle of water" - which is VERY different from other stories of "filled to the brim".
Bottomline:
1. We don't know how much water is in the trenches
2. It would be good to learn how water rthere is
3. And if the trenches has been reported dry since the tsunami
and
4: Has these trenches been regularly checked for water seeping out of the containment?
  • #1,788
Pump highly radioactive water to an area where it can be heated and release more radioactive delayed neutron precursors or accelerate gamma or Beta emitting dispersal?
Not a good idea.
  • #1,789
PietKuip said:
This failure in reporting is the incompetence of journalists and "experts", at NHK and other places. Some of them get it right, though. For example this guy: http://yokosonews.com/live/ He reported accurately that the true dose rate might be several times higher. And he seems to be mainly a culture and entertainment reporter. It seems that he had his info straight from watching a Tepco press conference...
Katz from Yokoso News is a legend! He has been broadcasting, whilst monitoring and translating several Japanese sources simultaneously. 10 hours a day since the crisis started, all with great professionalism and humour.
  • #1,790
Guys. If radioactive water keeps leaking and outside to the Pacific Ocean. How many miles off shore will the danger remain? I only eat fish and concerned about this.
  • #1,791
ZAMG is the state meteorological and geophysical services in Austria (link provided in my original post), in mundane terms it's the Austrian weather channel.
I quoted the actual report rather than a press mixed version (press did not even bothered linking there source).
In the initial paper produced by the Zamg Dr. Gerhard Wotawa explains that they only feed 2 measuring points to there mathematical model extrapolating from data from the first few days.
This model gave result that are up to 40 points different from an other model based on similar data.
It does raise the question of reliability on what is presented as hard fact, in my opinion.
  • #1,792
I'm sorry, but does this discussion need to be a post apocalyptic (re: Joe Neubarth type of speculative fiction) or a valuable resource toward possible solutions?
Sorry Joe, you see the negative 10E* potential outcome in your fiction, but that is the nature of fiction. And with respect you help make my point clear.
I suggest something different.
There are thousands of people who could contribute toward amortization of this issue. The first step is (in a situation like this) a forensic analysis of what went wrong. This is missing (with respect to time). A very top down kind of analysis has been occurring. Who's asking what happened in the first hour.. minutes, 2hrs. + 24hrs.
The young minds who regularly contribute to this forum could be a sounding board + all others toward a bottom up analysis (which in this case needs to happen faster than normal) in order to participate in potential solutions with regard to substantive input.
What happened in the first hr. after main power loss? (not just a summary)?
What happened in the first 12 Hr. Re: after main power loss and backup failure?
What decisions were made based on 'then' expectations and loss of data?
I think this is a case where forensic analysis would be better served as a balance between speculation and hypothesis WRT initial conditions leading outward where possible. Followed by the active post-forensic approach that is seemingly dominant.
  • #1,793
so we are talking about the rods in the pool
M. Bachmeier,
Tepco did not provide data for the first 12h or so.. Mitsuhiko Tanaka pointed just like you did that the first 12h are crucial to understand what could have happen.. from the initial data he does figure a few thing
Reactor 1 Core vessel at t+12 is at 0.80Mpa donw from 7MPa , First reading of Containment Vessel is at 0.8Mpa (twice the design spec) up from 0.1MPA normal operating pressure.
  • #1,794
A very quick and dirty back of the envelope:
length of beach, let's say 500m on both sides of the factory, makes 1000m
area up to 500m from shore
average depth between beach and 500m distance: 100m
makes a volume of 5x10^7 m3
If you consider dumping for example 5000m3 of highly contaminated waste, you would dilute it by a factor 10'000.
(if uniformly distributed, not considering fish living close to the pipes leading into the sea, those I would avoid)
In my opinion, sea pollution is less of a problem than land pollution because of its 3 dimensions (on land Cs will stick to a certain limited depth where the plants have roots).
  • #1,795
How do you explain this?
Goldman Sachs Employees Told Not to Leave Japan
http://www.cnbc.com/id/42304574
  • #1,796
What french calculation are you quoting?
Anyway, is there another dispersion model calibrated with CTBTO data available? The ZAMG model (the national authority to analyse CTBTO data in Austria) does a good job on the prediction of radioactive emission according to their recent http://zamg.ac.at/display.php?imgPa...urce=©+ZAMG&imgWidth=1199&imgHeight=740"
They also made a nice animation of the model available to the public:http://zamg.ac.at/pict/aktuell/20110325_Reanalyse-I131-Period1.gif"
  • #1,797
My nephew is the taller guy asking questions in English.
  • #1,798
From the OSTI report - the ambient temperature was 15°C. I expect the temperatures in core are much high - ~ 200°C or higher, especially if proper cooling is not obtained.
The PuO2 microspheres were also stoichiometric oxide, as opposed to irradiated fuel with a spectrum of fission products, so of which, e.g., I, Cs, Br, Rb are readily soluble in water.
  • #1,799
I have been following this thread out of curiousity. And after such a long time, people still talking about possibilities just tells me something is wrong.
What i think is even if there is a catastrophic radiactivity, it will be held confidential for various reasons. And people will start talking about Fukushima again when cancer rates around the region increases ten times..
  • #1,800
Well, speaking about what happened early on, Unit 1 blew up immediately after venting. That might make operators reluctant to go ahead and immediately vent Units 2 and 3. So pressure builds until Unit 2 and 3 explode. Unit 2 blows through the torus suppression pool without a lot of external damage to the building. Plutonium doesn't get on the ground that way. But Unit 3 was, as Ed Sullivan might have said, a "big, big, really big" explosion. My best analysis of the photos says it blew up and out of the south end of the top floor of Bldg. 3. If the source were from inside the primary containment and it didn't blow out of the torus pool, then it blew the drywell cap, came out the side of the primary containment, through the chute, and into the SFP.
That, to me, seems the most likely route to get Pu out, up, and back down on the ground.
Correct me if I am wrong, but there was no Plutonium in the SFP at Unit 4, right?
49K
449K
273K
16K
11K
