Help Needed: Solving A.P. Physics Homework Problem
The discussion revolves around solving a physics problem involving three blocks connected by strings over a pulley. The initial calculations for acceleration and tension are incorrect due to not accounting for the tension forces acting on the blocks. Participants emphasize the importance of using Newton's second law and setting up two equations that incorporate both acceleration and tension. A suggestion is made to draw free body diagrams to visualize the forces acting on each block. The conversation highlights the need to correctly sum forces to find the net force and subsequently the acceleration of the blocks.
vinny380
This question, from a previous A.P physics exam, was given as a homework problem. I am wondering if anybody could tell me if I am on the right track or totally wrong.
Three blocks of masses 1.0, 2.0, and 4.0 kilograms are connected by mass less strings, one of which passes over a frictionless pulley of negligible mass, as shown above. Calculate each of the following.
a. The acceleration of the 4 kilogram block
b. The tension in the string supporting the 4 kilogram block
c. The tension in the string connected to the l kilogram block
(Sorry but I can't seem to get the pic on here- basically on one side of the pulley is a 4kg mass, and on the other side is a 2kg mass that is connected by a string to a 1kg mass)
A. F=M*A
F= (3kg)(9.8)
F=29N
29N=(4kg)(a)
A=7.25m/s^2
B. 29N ? I basically got this calculation from above when finding the acceleration, but i am not sure if this is what they are looking for
C. Ft=M*A
Ft= (1kg)(7.25)
Ft= 7.25N
For some reason, I am really confused with this problem. Please help!
You may want to draw free body diagrams of all the forces acting on each block. I would make the 2kg and 1kg blocks into a single block of mass 3kg. Don't forget the tension in the strings.
Thats what I did in part A ...combined the 2kg mass and the 1 kg mass to form th 3kg mass...was that not correct?
It was indeed correct, however, gravity is not the only force acting on the blocks; you are forgeting the tension in the string.
hmmmmm...then how could i solve for the tension force?? And would that change the answer for A?
Yes it would change your answer to part a. You need to sum forces and use Newton's second law;
\sum \vec{F} = m\vec{a}
Note that the tension in the string in this case is uniform and that the acceleration is also uniform and equal for both particles.
I understand that I have to use F=MA to find all the forces to find the acceleration. But I thought I accounted for that by multiplying 9.8 * 3kg=29N ...would I have to multiply 4kg*9.8.. and then subtract?
So, 39N-29N=10N
10N= (4kg)(a)
10N/4=A
A=2.5ms^2?
Here I'll set up the two equations for you;
(1)4g - T = 4a - The tension is acting in the opposite direction of motion.
(2)T - 3g = -3a - The tension is acting in the same direction of motion.
I really would recommend drawing a free body diagram.
Edit: nrqed seems to explain it better than me
A. F=M*A
F= (3kg)(9.8)
F=29N
29N=(4kg)(a)
A=7.25m/s^2
Your F is only the weight of the combined 3 kg. It is NOT the net force on that mass since you are not including the tension. So you cannot use the 29 N to get an acceleration (an acceleration requires the *net* force).
You will have to set up two equations with two unknowns; the unknowns will be the acceleration and the tension. The two unknowns will appear in both equations.
As Hootenanny said, you really have to draw a free body diagram first.
(2)3g + T = 3a - The tension is acting in the same direction of motion.
Unfortunately, this is incorrect. The two acceleration terms should have opposite signs (otherwise it would imply that both masses accelerate in the same direction which is impossible) and the tensions must have the same sign (the tension is opposite to the gravitational force for both masses).
I think it is easier to start this way:
For the 3kg mass (call this mass A), we have
-(3 kg) g +T = (3kg) (a_y)_A
for the second one we have
-(4 kg) g + T = (4 kg) (a_y)_B
Now, if one mass is accelerated upward, the second mass will necessarily be accelerated downward, so (a_y)_A= - (a_y)_B . then we have
-(4 kg) g + T = - (4 kg) (a_y)_A
I apologise, but I realized I had made a mistake and edited my post, but it must not have showed up immediatly. :frown: Congratulations on your medal btw, well deserved.
Thank you Hootenanny, and thanks for recommending me :smile: :smile:
(btw, I think you forgot to change the sign of the tension in one equation...the tension is opposite to the weight for both the 3 kg and the 4kg).
Thanks again!
Patrick
Again, it is at the small obstacles I fall
Can't wait to see your avatar nrqed . :D
