How Do You Calculate Vertical Velocity and Energy Efficiency of a Ball Launcher?
  • Thread starter Thread starter ilysukixd
    Launcher Project
To calculate the vertical velocity of a ball from a launcher, the initial velocity is crucial as it determines the initial kinetic energy. The kinetic energy can also be derived from the work done on the ball, such as using a spring with a specific spring constant. Gravitational potential energy at launch is calculated using the formula mgh, where h is the height above a reference point. Energy efficiency is defined as the ratio of the kinetic energy of the launched ball to the energy input required to operate the launcher. Understanding these concepts is essential for analyzing the performance of ball launchers.
ilysukixd
okay i have a question on determining the vertical velocity of a ball that leaves it launcher
i'm not sure if it is the initial vertical velocity on the lst part of trajectory
second question, how do you determine the kinetic energy of the ball at launcher(based on total initial energy v) and determine gravitational energy of the ball at launch
Last question how do you determine the energy efficiency of the launcher
This is a physics question rather than a mathematics question so I am going to move it.
If you know the initial velocity of the ball, that, of course, determines the initial kinetic energy. If, instead, you know how the launcher accelerates the ball to that initial velocity, you can use the work done on the ball. For example, it the ball is lauched by a spring with spring constant k, pushing the ball over a distance d, then the work done is (1/2)kd and that is the initial kinetic energy.
The gravitational potential energy is given by mgh where h is the distance above what ever you take as reference point.
Finally, the "energy efficiency" is the kinetic energy of the ball as it is launched divided by the energy you had to put into the launcher (compressing the spring, pulling back the arm, etc.).
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
