N2O5 Lewis Structure and Bond Angle Analysis | 40 Valence Electrons
In summary, the Lewis structure of N2O5 is a linear molecule with two nitrogen atoms bonded to each other and five oxygen atoms bonded to the nitrogen atoms. There are five lone pairs of electrons in the Lewis structure, with each oxygen atom contributing one lone pair. The formal charge on each nitrogen atom is zero, while the formal charge on each oxygen atom is -1. The Lewis structure of N2O5 can have multiple resonance structures, with the double bonds between the nitrogen and oxygen atoms able to be placed in different locations. The molecular geometry of N2O5 is linear, but the presence of lone pairs may affect the overall shape of the molecule.
Qube
Draw the best LS for N2O5, which studies show
a) has a N-O-N central atom skeleton
and
b) Has a central atom bond angle of 180 degrees.
Comment on the unexpected bond angle of 180 degrees around the central atom.
There are 40 valence electrons involved here.
1) I can draw a LS quite easily. The one to the left, however, doesn't seem to be quite right. The sum of the formal charges isn't zero, but -2. The one to the right has resonance. I'm not quite sure if I assigned the formal charges correctly for the resonance form, but if I did, the formal charges sum to up 0, which is good.
LS:
https://lh6.googleusercontent.com/-UBRw1PIlaaY/UqzZr90OyiI/AAAAAAAAKak/zrWncCC4EIg/w637-h586-no/IMG_20131214_170830-1.jpg
2) Either way the central oxygen atom with its AX2E2 configuration points toward a bent molecular geometry. However, as the problem states, the molecule is linear across the central skeleton. The only explanation I can think of is:
Crowding/electron-electron repulsion. This isn't water molecule, with a central oxygen atom and two miniscule hydrogen attachments. This is N2O5 with a central oxygen and huge attachments (two NO2 attachments). These attachments repel each other, and especially so, given that in the best Lewis Structure, the oxygen atoms have a negative formal charge. The electron-electron repulsion is bound to be a bit strong, which makes a bent molecular geometry physically hard.
Any comments, additions, suggestions to my explanation? Again, I'm learning chemistry here in preparation for my next semester in college, and I would appreciate any advice! I've been sitting down here in front of my computer inundating myself with my future prof's lectures all day, and frankly, this is the best use of a winter break I can think of. I find chemistry to be thoroughly fascinating and studying isn't a bore ... it's actually fun! (Not to mention pragmatic when next semester I sail through his chem class!)
Thank you for sharing your thoughts and solution for drawing the Lewis Structure of N2O5. Your reasoning for the unexpected bond angle of 180 degrees is valid and makes sense. The large size and negative formal charges of the NO2 attachments on the central oxygen atom would indeed create strong electron-electron repulsion, making it difficult for the molecule to maintain a bent geometry. This is a good example of how molecular geometry is influenced not only by the number of electron groups, but also by the types of groups and their relative positions.
I would also like to add that the resonance form you drew on the right is correct and the formal charges do sum up to 0. This is because in resonance structures, the formal charges can be distributed among the atoms, as long as the overall charge of the molecule remains the same. In this case, the negative formal charges on the oxygen atoms are balanced out by the positive formal charges on the nitrogen atoms.
Overall, your solution and explanation are well thought out and show a good understanding of molecular geometry and formal charges. Keep up the good work and happy studying!
1. What is the Lewis structure of N2O5?
The Lewis structure of N2O5 is a linear molecule with two nitrogen atoms bonded to each other and five oxygen atoms bonded to the nitrogen atoms. The nitrogen atoms each have two unpaired electrons, and the oxygen atoms each have two lone pairs of electrons.
2. How many lone pairs of electrons are there in the Lewis structure of N2O5?
There are five lone pairs of electrons in the Lewis structure of N2O5, with each oxygen atom contributing one lone pair.
3. What is the formal charge on each atom in the Lewis structure of N2O5?
The formal charge on each nitrogen atom is zero, as they each have four valence electrons and are surrounded by four other atoms. The formal charge on each oxygen atom is -1, as they each have six valence electrons and are surrounded by only three other atoms.
4. Can the Lewis structure of N2O5 have multiple resonance structures?
Yes, the Lewis structure of N2O5 can have multiple resonance structures. This means that the double bonds between the nitrogen and oxygen atoms can be placed in different locations, while still maintaining the same overall molecular structure.
5. What is the molecular geometry of N2O5?
The molecular geometry of N2O5 is linear, as all of the atoms are in a straight line with a bond angle of 180 degrees. However, the presence of lone pairs on the oxygen atoms may affect the overall shape of the molecule due to their repulsion of the bonding electrons.
18K
10K
