Loss due to open channel to pipe flow transition
The discussion centers on the derivation and application of the entrance loss equation for flow transitioning from an open channel to a pipe. The equation hloss = K*(V2^2 - V1^2)/2g incorporates both the upstream and downstream velocities, which is a departure from the traditional K*(V^2)/2g used for pipe entrances. The participants reference a book on hydraulic engineering that discusses loss coefficients for both contraction and expansion scenarios, noting that expansion losses are theoretically greater than contraction losses. However, practical calculations yield unexpected results, with contraction losses appearing larger due to the differing velocity terms. Overall, the conversation highlights the complexities in accurately modeling flow transitions between open channels and pipes.
miriza
Hi!
I have the following equation for the entrance loss from an open channel to a pipe, but I'm not sure how it was derived:
I have always seen entrance losses as: K*(V^2)/2g, but why is the channel flow velocity considered in the equation above.
Thanks, Michelle
Comes from the energy equation.
\frac{p_1}{\rho g}\,+\,\alpha_1\frac{\bar{V}^2}{2g}\,+\,z_1\,=\,\frac{p_2}{\rho g}\,+\,\alpha_2\frac{\bar{V}^2}{2g}\,+\,z_2\,+\,h_{l_T} from Robert Fox & Alan MacDonald, Introduction to Fluid Mechanics, John Wiley & Sons, 1978.
K*(V^2)/2g
is used with respect to the entrance of the pipe. V is the mean velocity. Perhaps the K's are different (?). Some additional discussion is needed.
I can't say that any of my references have this situation. It's either open channel or pipe, not a combination. I will look around to see what I can find as well.
Fred and Astronuc:
Thanks for the help...
Just to add more info: The case I'm interested in is an open channel discharging into a box culvert and then back into an open channel.
I actually found a reference that has a similar equation, but I'm still not sure exactly how it was derived. The book is "Hydraulic Engineering" by Roberson, Cassidy and Chaudry (1988 Houghton Mifflin). There is a section on channel-flume transitions where it says:
*For an inlet transition (contraction): the loss would be KI * V^2/2g, where KI is the loss coefficient for the transition and V is the velocity of the downstream conduit (the highest mean velocity), which would be the pipe velocity in my case of channel to culvert flow.
*For an expansion, the head loss would be KE (V1^2-V2^2)/2g where KE is the loss coefficient for the expansion, V1 is the mean velocity at the upstream end (culvert in my case) and V2 is the mean velocity at the downstream end (open channel in my case).
Expansion losses in theory should be greater than contraction losses. However, when I use the 2 equations above I get much greater contraction losses (probably because there is only one velocity term in the contraction loss). I'm really lost here...any clue?
Thanks, Michelle
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
