Magnetic Field and potential difference
Electrons are accelerated through a potential difference of 351 V and move in a circular path of radius 0.743 cm within a perpendicular magnetic field. The magnetic field strength was calculated to be 8.50 mT, and the current through the coils was found to be 6.15 A. For a proton to follow the same circular path, it would require a voltage of 0.190 V, which was initially deemed incorrect due to significant figure errors. The discussion highlighted the importance of considering the charge sign difference between protons and electrons when calculating voltage. Overall, careful attention to significant figures and charge polarity is crucial in these calculations.
strawberrysk8
Electrons are accelerated from rest through a potential difference of 351 V. Then these electrons enter a uniform magnetic field that is perpendicular to the their initial directon. Due to the interaction with the magnetic field, they move in a circular path of radius 0.743 cm.
a) What is the magnitude of the magnetic field?
The magnetic field was generated by a Helmhotz coil pair. You measure the coils and determine that the average diameter is 169 mm.
b) What is the magnitude of the current through the coils?
Assume a proton has a mass 1849 times greater than the electron. Its electric charge is the same magnitude as that of the electron, but it is positive instead of negative.
c) What voltage would the proton have to be accelerated through for it to move in the same circle as the electron in parts a and b?
e/m = 2V/[(B^2)(r^2)] = [125(V)(R^2)] / [32(N^2)(u^2)(I^2)(r^2)]
N = 130
u = 4(3.14)(10^-7)
e = 1.6*10^-19C
m = 9.11*10^-31kg
a) V = [e(B^2)(r^2)] / [2m] = 8.50mT
b) I = [125(m)(V)(R^2)] / [32(e)(N^2)(u^2)(r^2)]^(1/2) = 6.15A
c) V = [e(B^2)(r^2)] / [2(m)(1849)] = 0.190V
but the 0.190V part is wrong. why?
If you are entering your answers online, you need to be careful with your significant figures. Using your answers from (a) and (b) I have a voltage of 0.189V to 3.s.f.
that still turned out to be wrong. hmm...what else could be the problem? can voltage be negative?
That would make sense, since the proton and electrons have opposing signs.
thx so much!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
