Magnetic Field Induced by Nonuniform Electric Flux
The discussion focuses on calculating the amplitude of the induced magnetic field generated by a nonuniform electric field between two circular plates in a Doppler radar unit design. The electric field is defined as E = (700 V/(m sec2))*(1-r/Rp)*t2, where Rp is the plate radius. The correct approach involves integrating the electric field over the area to find the electric flux, followed by taking the time derivative to determine the induced magnetic field. The initial calculation of B = 1.69E-16 was incorrect due to improper handling of the electric field's nonuniformity.
  • Understanding of electromagnetic theory, specifically Maxwell's equations.
  • Familiarity with electric field calculations and flux integration.
  • Knowledge of magnetic field induction principles.
  • Proficiency in calculus, particularly double integrals.
  • Learn about the application of Maxwell's equations in electromagnetic fields.
  • Study the process of calculating electric flux using surface integrals.
  • Explore the concept of induced magnetic fields in varying electric fields.
  • Practice solving problems involving double integrals in polar coordinates.
Students and professionals in electrical engineering, physicists, and anyone involved in the design and analysis of electromagnetic systems, particularly in radar technology.
Badre
During the design of a new doppler radar unit, you have two circular plates with radius R = 3 cm and a plate separation of d = 5 mm. The magnitude of the electric field between the plates is given as:
E = (700 V/(m sec2))*(1-r/Rp)*t 2
where Rp is the radius of the plates, t is the time in sec and r is the distance from the axis of the plates (for r < Rp ).
a) What is amplitude of the induced magnetic field a distance 1.5 cm from the center axis joining the plates at time t = 2.9 sec?
∫B.ds = [itex]\mu_{0}[/itex][itex]\epsilon_{0}[/itex] d[itex]\Phi[/itex]e/dt
I did this problem as I worked out previous ones, taking the time derivative of the electric field to find the changing electric flux.
B=[itex]\mu_{0}[/itex][itex]\epsilon_{0}[/itex] pi*r^2/2*pi*r * dE/dt
B=[itex]\mu_{0}[/itex][itex]\epsilon_{0}[/itex] (.015/2) * 2*700t(1-.015/.03)
B = 1.69E-16
This answer is rejected by the software. I'm at a loss for what I'm missing here. I don't understand why I'm given the separation between the plates, I suspect that may be involved in the solution but I'm not seeing how. Thanks for any help.
Okay, I think I see what you are doing here (it took me awhile to figure out your above result).
When you tried to calculate the flux, you just multiplied the electric field E by the area, πr2. That would work if the electric field was [STRIKE]constant[/STRIKE] uniform within the entire circle defined by r (it can be time changing, but at a particular point in time it must be uniform across the surface defined within r). But it's not [STRIKE]constant[/STRIKE] uniform for this problem. (Although due to symmetry, the magnetic field strength is [STRIKE]constant[/STRIKE] uniform around the perimeter 2πr, which is why the ∫B·ds = B[2πr] part worked okay.)
You're going to have to do an integration, one way or the other. You have two choices. You can calculate the flux directly via
[tex]\Phi_E = \int_S \vec E \cdot \vec{dA},[/tex]
and then take the time derivative to find [itex]\frac{\partial \Phi_E}{\partial t}[/itex]. Or, you can take the time derivative first to obtain [itex]\frac{\partial E}{\partial t}[/itex], and then evaluate
[tex]\frac{ \partial \Phi_E}{\partial t} = \int_S \frac{\partial \vec E}{\partial t} \cdot \vec{dA}.[/tex]
Either way works fine.
It may be useful to note that in polar coordinates, [itex]dA = r \ dr \ d\theta[/itex].
Thanks! Haven't had to do a double integral before now.
  • · Replies 16 ·
