Magnitude and direction of the force of the seat on you?
The discussion revolves around calculating the force exerted by the seat on a rider at the bottom of a roller coaster loop. The rider's speed is 20 m/s, and their mass is 50 kg, leading to a derived centripetal force equation. The normal force at the bottom is calculated using the formula N = mg + mv²/r, resulting in a value of 2,490 N. Participants emphasize the importance of understanding the physics behind the equations rather than just memorizing them. The conversation highlights the relationship between gravitational force and centripetal force in determining the total force felt by the rider.
charan1
One fine spring day you decide to skip class and go to the amusement park to ride the loopthe-
loop roller coaster. At the bottom of the loop, you’re moving with a speed of 20 m/s in a vertical circle 20 m
in diameter. What’s the magnitude and direction of the force of the seat on you? Assume your mass is 50 kg.
Vt=omega x radius
Fr=mass x omega2 x radius
Vt=omega x radius
20m/s=omega x 10m
omega=10 rad/s
Fr=50kg x 10rad/s x 10m
=5,000 N
I'm not sure what I'm doing at all on this problem please help me out.
I drew the FBD and the only forces are the Normal which I assume is the seats force on the rider which I further moved towards thinking that would be the Force towards the center thus the equation
Fr=mass x omega2 x radius, and the other force is (of course) g.
Please help me out I am in a bit of confusion.
Thank you for reading!
-Charan
F(centripetal)=V^2/R because you are moving in a circle there is a centripetal force, always. At the bottom it is opposite of weight and the normal you feel is w-Fc at the top it is creating a normal if I remember correctly. so It is Fc+W=N
Oh I see thank you I also just found it in my book
at the bottom N=mg+mv2/r
and at the top N=mv2/r - mg
so in this case it is asking for the Normal force at the bottom and that is the first equation.
so:
N=(50kg)(g) + (50kg)(20m/s)2/10m
N=2,490N
Charan,
Just so you know how to get that equation and not memorize it, here are some steps you might take to help you understand why that is the case.
First draw a free-body and analyze the forces acting on you due to the seat. After drawing the diagram you will see that you have a Fn going up and a Fw going down. So if you use Newtons second law you get.
Efy=ma(c)
Fn-Fw=m(V^2/r) -----> Fn=Fw+m(V^2/r)
It will probably stick better if you understand why those equations are true
so:
N=2,490N
That's all very well, but please don't blindly find formulas in the book and try to apply them without understanding them.
When you are at the bottom, then Fseat is upward and your weight Mg is downward.
Therefore Fr = Fseat - Mg
Also Fr = Mv^2/r
Therefore Mv^2/r = Fseat - Mg
Fseat = Mv^2/r + Mg
Solve the above to calculate Fseat.
For centripetal force, you have used M*omega^2*r. That is also correct, but in this problem, v is given. So it is easier to use Mv^2/r
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
