Maximizing the distance of a projectile
  • Thread starter Thread starter IDumb
    Projectile
The optimal angle to maximize the distance of a projectile, specifically in the context of spitting, is 45 degrees when launched from ground level (h = 0). When the launch height (h) is greater than zero, the relationship between launch angle, initial speed, and maximum distance becomes more complex. The equations derived include the vertical motion equation, py(t) = -4.9t² + vyt + h, and the horizontal motion equation, px(t) = vxt. The analysis indicates that the launch angle may vary with both height and initial speed, which requires further investigation to clarify the relationship.
  • Understanding of projectile motion equations
  • Familiarity with calculus, specifically differentiation
  • Basic knowledge of trigonometric functions and their applications
  • Experience with numerical methods or computational tools for solving equations
  • Explore the effects of varying launch heights on projectile motion
  • Learn about the derivation of projectile motion equations in detail
  • Study the application of calculus in optimizing functions
  • Investigate numerical methods for solving complex equations in physics
Physics students, engineers, and anyone interested in understanding the principles of projectile motion and optimization techniques in real-world applications.
IDumb
1) This is not a homework problem, just a question I came across and can't solve adequately.
2) Sorry if this is wrong area to post it.
What angle would be best to hold your head at relative to ground to maximize the distance you can spit.
I drew a diagram, horizontal axis was distance in the x direction, vertical axis was distance in y direction. I drew a vector for velocity, V0 at an angle \theta relative to ground. vx and vy represent the x and y components of this initial velocity vector. The initial velocity starts from a height of h.
I then divided it into 2 equations, the acceleration in the y and x directions.
The Y direction:
ay = -9.8 (m/s2)
integrate twice to obtain position function:
py(t) = -4.9t2 + vyt + h
Next, I found the time, t1, that the projectile (saying spit sounds weirder) would reach ground, at y = 0.
py(t1) = 0
using the quadratic equation I obtained 2 results, 1 of which had to be negative. So the other one is the time we want.
t1 = Vy/9.8 + (1/9.8)(\sqrt{v<sub>y</sub><sup>2</sup> + 19.6h})<br /> <br /> OK, so at this time, we will have y = 0 and x = D, the farthest distance the projectile will reach.<br /> <br /> The x equation:<br /> a<sub>x</sub> = 0 --&gt; v<sub>x</sub>(t) = v<sub>x</sub> --&gt; p<sub>x</sub>(t) = v<sub>x</sub>t<br /> <br /> replace t with the value found for t1, because that will give us an equation for D, the maximum distance.<br /> v<sub>x</sub>(t1) = D = \frac{v<sub>x</sub>v<sub>y</sub>}{9.8} + (1/9.8)(v<sub>x</sub>\sqrt{v<sub>y</sub><sup>2</sup> + 19.6h)
Okay, so how are vx and vy related to the launch angle and the projectile speed?
meh, sorry, had some issues posting it must have gotten deleted.
I subbed in vx = v0cos(\theta) and vy = v0sin(\theta). Then i took dD/d\theta. Set it = 0, used a computer to solve it.
at angle of 45
NEILS BOHR said:
at angle of 45
Sure, if h = 0. What if h \neq 0?
That's the issue. At h = 0 it simplifies easily. I get a messy equation for D with respect to theta. Leading to stupid mistakes when taking the derivative to find the critical points. I used a computer to solve what I had, and I got angles that varied with both height and the magnitude of the initial speed. That can't be right though, the angle shouldn't vary with the initial speed's magnitude.
  • · Replies 23 ·
  • · Replies 30 ·
