N-slit Interference/Diffraction
  • Thread starter Thread starter Warr
The discussion focuses on the intensity equations for N-slit interference and the confusion surrounding the transition from two slits to N slits. The intensity for two slits is given as A^2={A_2}^2(sin^2(φ/2)/(φ/2)^2)cos^2(β/2), while for N slits, it is A^2={A_N}^2(sin^2(φ/2)/(φ/2)^2)(sin^2(Nβ/2)/sin^2(β/2)). A participant questions whether substituting N=2 in the N-slit equation results in an expression that is four times the two-slit equation, suggesting a possible error. The consensus is that the peak intensity should indeed be proportional to the number of slits squared, affirming the mathematical relationships involved. This highlights the importance of careful manipulation of the equations in optics.
Warr
Hi, having trouble determining whether my lab book has made an error, or I have.
Intensity as a function of \phi for 2 slits is given as
A^2={A_2}^2\frac{sin^2(\frac{\phi}{2})}{{(\frac{\phi}{2})}^2}cos^2(\frac{\beta}{2})
but then it gives the amplitude for N slits to be
A^2={A_N}^2\frac{sin^2(\frac{\phi}{2})}{{(\frac{\phi}{2})}^2}\frac{sin^2(\frac{N\beta}{2})}{sin^2(\frac{\beta}{2})}
However, when I sub in N = 2 for the equation (2), and use the double angle formula to reduce the right fraction in equation (2) I get 4*equation(1) rather than just the equation(1) alone. Am I doing it wrong?
To be more succinct, isn't \frac{sin^2(\frac{N\beta}{2})}{sin^2(\frac{\beta}{2})} = 4cos^2(\frac{\beta}{2})?
I don't have my optics references handy, but I don't think you're doing anything wrong.
I'd say that should be:
A^2={A_0}^2\frac{sin^2(\frac{\phi}{2})}{{(\frac{\phi}{2})}^2}\frac{sin^2(\frac{N\beta}{2})}{sin^2(\frac{\beta}{2})}
It makes sense that the peak intensity should be proportional to the number of slits squared.
