Max Depth of Platform on Spring Calculator
  • Thread starter Thread starter godindisguise
    Springs
The discussion revolves around calculating the maximum depth reached by a platform supported by a spring after a fly jumps off it. The initial equations provided, such as F = -kx and the conservation of momentum, are crucial for understanding the dynamics involved. Participants express confusion about how the fly's jump relates to the platform's movement and seek clarification on the energy transfer during the jump. The conversation suggests considering the fly's kinetic energy and momentum to determine the spring's maximum extension after the jump. Ultimately, the focus is on applying physics principles to solve the problem effectively.
godindisguise
A wingless fly of mass m sits on top of a platform of mass M supported by a spring of constant k. At time t the fly decides to jump upwards and by doing so, reaches a maximum altitude of 2d above the equilibrium point of the unloaded spring (i.e. the spring without the platform and fly). Assuming that the spring has no mass, find what is the maximum depth reached by the platform.
F=-kx
I have no idea how the fly jumping up a certain height has anything to do with the depth at which the spring originally was...the most simple answer I could come up with:
F = -kx
mg+MG = -kx
x = -g(m+M)/k
Thanks
That looks correct for the initial position of the spring. The question is about what happens AFTER the fly jumps. What happens to the platform, after the fly jumps off it?
Thanks..but REALLY need some more help...
Imagine somebody made a video of this and played it backwards.
You see the fly falling from a given height onto the platform mounted on a spring. (Imagine its a big fly and a small platform). Does that remind you of any type of problem you have seen before? What equations would you use to solve it?
I am a little confused by the question. Like the original post, I can't see how the fly's height would mean anything. If anything, wouldn't this just cause the spring to release slightly?
after the fly jumps, the fly gains momentum. by the conservation of momentum, what is the momentum of the platform immediately after the fly jumps? (hint: consider the energy of the fly)
the following equation may be helpful:
KE=\frac{p^2}{2m}
from there, how can you find the maximum extension of the spring?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
