Net Force Worksheet: Solving Acceleration, Mass & Friction Problems
The discussion revolves around solving physics problems related to a top fuel dragster's acceleration, mass, and friction. The dragster has a mass of 3000 kg and accelerates at 60 m/s², leading to a calculated net force of 180,000 N. There is confusion regarding the engine force and how to approach the problem, particularly with increasing friction at higher speeds. Participants suggest using free body diagrams (FBD) to visualize forces and emphasize the importance of understanding friction-based propulsion. Clarifying these concepts will help simplify the problem-solving process.
vinboi
A top fuel dragster accelerates at six times the acceleration of gravity. Its mass is 3000kg and it has an initial frictional force of 6000N
M = 3000kg
A = 60ms-2 (Lets just say gravity = 10ms-2 down)
a) What is the total force?
b) What is the engine force?
c) At 300km/h the frictional force has increased to 50,000N, what is its acceleration at this speed?
a) Fnet = MA
= 60*3000
= 180,000N or 180kN
b) Sorry I have no idea what this is asking for
c) Sorry I have no idea what this is asking for
Basically I don't understand what to do in those questions. If anyone could point me in the right direction it'd be greatly appreciated
How does friction-based propulsion work?
If you can answer that, the question should become fairly simple.
Remember Newton's third law, and take into consideration what you do when you walk, you push off the ground, right?
Try drawing an FBD for the car, and for the FLOOR. The net force on the floor is NOT 0 (Though its acceleration in the direction opposite the movement of the car is completely negligible)
