How Does Newton's Second Law Apply on an Inclined Plane?
  • Thread starter Thread starter flatline4520
    2nd law Law Plane
The discussion focuses on applying Newton's Second Law to a sled moving down an inclined plane with a 60° angle and a kinetic friction coefficient of 0.1. The user calculates the net force acting on the sled but receives incorrect answers, leading to confusion about the direction of the friction force and the calculation of gravitational components. They correctly identify the normal force but struggle with the calculation of the net force, specifically the sine component of the gravitational force. Clarifications about the direction of friction and the correct application of trigonometric functions are sought to resolve the discrepancies in their calculations. Accurate understanding of these concepts is essential for solving problems involving inclined planes and forces.
flatline4520
A sled moves on the flat surface of a hill. The hill makes an angle θ with the horizontal, and is left orientated.
The hill: θ = 60°; left oriented; μk = 0.1.
The sled: mass = 20 kg; starting location = 20 m from the bottom of the hill;
initial speed = 0 m/s .
http://img26.imageshack.us/img26/1756/blockoninclineleft.jpg
Solve:
  1. (Fnet)x immediately after motion begins, (N)
  2. (Fnet)x, sliding down the hill, (N)
<br /> \vec{F}_{net} = \Sigma \vec{F} = m \vec{a}<br />Fn = mg cos θ
Fn = 98
I draw an FBD and every time I solve for (Fnet)x I get:
(Fnet)x = -mg sin θ - μk*Fn
(Fnet)x = 59.742 - 9.8
(Fnet)x = 49.9 N
Every time I input that as my answer it says it's wrong. Also why is it that the kinetic friction force is a positive 9.8. Doesn't the friction go in the opposite direction of the motion?
Thanks for help
Welcome to PF.
If a positive friction indicates that to the right is positive and to the left is negative
Hi
Thanks that cleared up the friction.. Do you know what I'm doing wrong with the (Fnet)x ?
Thanks for the help
According to my calculations, mg sin(60) (9.8*20*sin(60)) doesn't come out to 59.742...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
