semidevil
- 157
- 2
the only tables that I see go from -3 to 3 in my textbooks. but I keep seeing problems on the textbooks tha ask for p( -4.5 < z < .5)
how do I solve this?
Nenad said:what are you talking about? Be more specific.
Regards,
Nenad
There are several options. Web Site #1 below offers interactive calculation of both Normal Distribution and Inverse Normal Distribution for {-7.0 < z < +7.0}. Web Site #2 provides tabulated values of Normal Distribution tail probabilities for {0 < z < +9.5}, with larger "z" values given in the extended table below the main table. Finally, you can calculate your own Normal Distribution CDF's from Equations #10-14 and other references given in Web Site #3 below.semidevil said:the only tables that I see go from -3 to 3 in my textbooks. but I keep seeing problems on the textbooks tha ask for p( -4.5 < z < .5)
A normal distribution table, also known as a standard normal table or z-table, is a mathematical tool used to find the probability of a specific value occurring in a normal distribution. It is typically used in statistics and probability to calculate the area under the curve for a given value or range of values.
A normal distribution table is used to find the probability of a specific value occurring in a normal distribution. This is done by finding the corresponding z-score (standard deviation) for the given value and looking up the corresponding probability in the table. It can also be used to find the area under the curve for a given range of values by subtracting the probability of the lower value from the probability of the higher value.
A standard normal table is a specific type of normal distribution table that is used when the mean of the distribution is 0 and the standard deviation is 1. This makes it easier to calculate probabilities and areas under the curve. A normal distribution table, on the other hand, can be used for any normal distribution with any mean and standard deviation.
Normal distribution tables can be found in many statistics textbooks and online. They are also often included in statistical software packages or calculators. It is important to make sure you are using a reliable and accurate table for your calculations.
No, a normal distribution table is only applicable for normal distributions. For non-normal distributions, other statistical methods and tables may be used to calculate probabilities and areas under the curve.
