Physics Problem: Flight Attendant and 70N Bag
  • Thread starter Thread starter XxClueLess5xX
    Flight Physics
The problem involves a flight attendant pulling a 70 N bag with a force of 40.0 N at a 52-degree angle over 253 m. To find the work done, the horizontal component of the force must be calculated using the cosine of the angle. The work is then determined by multiplying this horizontal force by the distance moved. Participants in the discussion are encouraged to share their calculations and methods for solving the problem. Understanding the physics concepts of force, angle, and work is crucial for finding the solution.
XxClueLess5xX
ok I am in physics obviously...and I am having an extrmely hard time. can anyone help me with this problem?
- a flight attendant ulls her 70 N flight bag a distance of 253 m along a level airport floor at a constant speed. the force she exerts is 40.0N at an angle of 52 degrees above the horizontal. find the following t work she does on the flight bag.
:eek:
What have you done so far?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
