Calculating Orifice Profile and Plate Thickness for 48" Pipeline
The discussion focuses on calculating the orifice profile and plate thickness for a 48" pipeline with air as the medium, operating under specific pressure conditions. The target pig speed is 0.5 m/s, with upstream pressure at 17 barg and downstream at 0.2 barg, indicating critical flow conditions. Participants discuss the formula for calculating the speed of sound in the pipeline and the resulting volumetric flow to determine the orifice area. One user estimates an orifice diameter of approximately 63 mm using a discharge coefficient (Cd) of 0.8, while another suggests that a Cd of 0.6 may be more accurate. Accurate calculations are essential for effective pig speed control in the pipeline.
badri2221
We have a situation where we have air in front of the dry pigs and need to control the pig speed
Medium is air, pressure is 17 barg upstream and 0.2 barg downstream and pig speed target is O.5 m/s for the pig in the 48" pipeline with a pressure of 17 barg.
need to find the following:
Orifice profile (hole) size?
Plate thickness
For these upstream and downstream conditions the flow is critical, sonic, or "choked" which means the velocity is limited by the speed of sound in the orifice throat.
So a quick estimate is to calculate the speed of sound in the pipeline:
v_sonic = sqrt (k R Tstar)
k = isentropic exponent
R = gas constant
Tstar = 0.8333 Tgas
The volumetric flow is:
V_flow = v_sonic * A_orifice
and solve for A_orifice which is the area of the orifice. Then you can find the orifice bore size from this area.
thanks , i have tried to model it on massflow and Cd as 0.8 landed around 63 mm dia
Glad to hear you have this running. I think CD of .6 is closer for an orifice.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
