Phase angle between peak source voltage and peak voltage across RLC?
The discussion revolves around an LRC series circuit with specified resistance, inductance, and capacitance values, powered by an AC voltage source. Participants are tasked with determining the peak voltages across the circuit components and their phase angles relative to the source voltage.
  • Participants explore the relationship between the phase shift and the circuit components, questioning how to apply the phase shift formula. There are discussions about using complex impedance to find the total impedance and current phasors, as well as the individual voltage drops across components.
Some participants have provided suggestions for calculating impedance and voltage drops using complex representations. There is an ongoing exploration of how to relate the phase angles to the voltages across the components, with no clear consensus yet on the best approach.
Participants are navigating the complexities of AC circuit analysis, including the distinction between peak and RMS values, and the definitions of reactance versus impedance. There is also mention of potential terminology confusion regarding the representation of reactance.
Loopas
An LRC series circuit with R = 200Ω , L = 31mH , and C = 1.8μF is powered by an ac voltage source of peak voltage V0 = 540V and frequency f = 550Hz. What are the peak voltages across the inductor, capacitor, and resistor and their phase angles relative to the source voltage?
Phase shift = [itex]tan^{-1}[/itex]([itex]\frac{XL - XC}{R})[/itex]
I already found the peak voltages across the components.
I can't figure out how to find the phase angles between the source voltage and the peak voltage across the circuit components. Is the phase angle between the voltages found using this equation?
I don't want to say no, but not necessarily, the phase shift function is different for all circuits. Basically, you have a real part and an imaginary part (this comes from your complex analysis that I'm assuming you've done already).
You'll end up with something like this:
[itex] V_{out} = V_{in}(f(R,L,C) + g(R,L,C)i)[/itex]
and this corresponds to the phase shift,
What you get is:
[itex]\phi=tan^{-1}(\frac{g(R,L,C)}{f(R,L,C)})[/itex]
See where this comes from? just plot it and I think it becomes rather obvious. The imaginary term is the y-axis and the real part is the x-axis.
Suggestion: Start by finding the impedance values for each of the components (complex representation). Then write the total impedance as their sum, Z = R + ZL + ZC. Find the current phasor for the circuit from the given source voltage and total impedance, I = E/Z, where E is the given 540V. Can you then find the individual voltage drops in their complex forms?
your v_out function (g and f) include all your
[itex][STRIKE]Z[/STRIKE]_{c} & X_{L} and R[/itex] terms. probably should've mentioned that previously.
Well I have [itex]\frac{V_{out}}{V_{in}}[/itex] = [itex]\frac{XC}{\sqrt{R^{2}+(XL-XC)^{2}}}[/itex]
How can I apply this to finding those functions that are part of the phase shift formula?
Is the individual impedance of the capacitor equal to XC? And for the inductor XL and resistor R?
I found the RMS voltage using I = Vsource/Z. After that I found the voltage across each component by multiplying the individual impedances by the RMS voltage.
Impedance is a complex value. XL and XC are called reactances, which is the magnitude of the impedance for those components. To make it more clear, the impedances of the three components are:
ZR = R + 0j = R
ZL = 0 + jωL = jXL
ZC = 1/(jωC) = -jXC
Since you're looking for peak values according to the question statement, and since the source voltage is given as a peak value, there's no reason to involve RMS conversions. And I think you meant that you found the current, not the voltage, using Vsource/Z. Other than that terminology issue your method sounds okay. Can you show your results?
If you have that, then you have:
[itex]V_{out}[/itex] = [itex]V_{in}\frac{XC}{\sqrt{R^{2}+(XL-XC)^{2}}}[/itex]
And I'm confused... is it XC or [itex]X_{c}[/itex]
But basically your goal at this point is to separate the real part (the R in the denominator) from the imaginary part the XC's and XL's and do what I said previously.
To clarify (again) where the v_in is is irrelevent. I just threw it on the RHS to relate it to my previous post.
  • · Replies 30 ·
11K
