How to Build a Ping Pong Projectile Launcher for Maximum Distance?
To build a ping pong projectile launcher capable of reaching distances of 4m and 10m, the design should be a catapult, with wood as the recommended material. The discussion clarifies that "respectively" refers to launching the ball twice for each distance. Various propulsion methods were considered, including compressed air, while explosive propellants were deemed impractical for a school project. Different catapult designs, such as ballistae and trebuchets, were mentioned as potential options. The thread concluded with a reminder for the original poster to demonstrate effort in their schoolwork before further assistance could be provided.
Ah Yiife
OP has been warned about posting schoolwork/homework without using the HH Template and showing some effort.
1. The shape of the ping pong launcher I think is 'catapult' but I don't know the suitable size and the materials need to use. The ping pong ball need to be launch to a distance of 4m and 10m respectively.
What are the size and materials used is most suitable to launch the ping pong ball this far ?
What does your "respectively" mean here? Are you building two different lauchers? I would certainly start with a pipe just large enough to fit a ping pong ball into. Then you have to decide how you are going to propel the balls. For example are you going to use gun powder or other explosive propellant? (Might be difficult to get a teacher's permission for that!) Are you going to use compressed gas, like air?
Sorry, my English is poor haha. Teacher suggests using the wood to make the catapult. 'Respectively' I mean is need to launch the ping pong ball twice. First distance is 4m and second distance is 10m. I think I am not going to use the gun powder and explosive propellant.
"Catapult" encompasses several designs.
A ballista is like a large crossbow, the energy being stored in the bending of a beam or twisting of ropes/sinews.
A trebuchet throws the missile from the end of a rotating arm, usually powered by a heavy weight on the other end.
Wikipedia might help you choose.
Thread is obviously locked. OP has been warned to re-post and show some actual work and effort on his/her schoolwork.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
