Airplane Velocity: Calculating Speed and Heading
The discussion focuses on calculating the speed and heading of an airplane in relation to wind conditions. The airplane's velocity is given as 160 m/s due east, while the wind's velocity is 32 m/s at a 30° angle west of due north. To find the plane's speed and heading relative to the ground, vector addition is necessary, combining the plane's velocity with the wind's velocity. Visualizing the vectors through drawings is recommended for clarity in understanding the resultant vector. The conversation emphasizes the importance of vector addition in determining the airplane's actual ground speed and direction.
anuurcc
You are traveling on an airplane. The velocity of the plane with respect to the air is 160 m/s due east. The velocity of the air with respect to the ground is 32 m/s at an angle of 30° west of due north.
1)What is the speed of the plane with respect to the ground?
2)What is the heading of the plane with respect to the ground? (Let 0° represent due north, 90° represents due east).
3)How far east will the plane travel in 1 hour?
I tried to set up the problem but can't visualize the vectors with respect to the wind angle given. Any help would be appreciated!
Draw pictures! %^), simple at first.
Suppose the plane heads north at 100mph but flies into a wind going 50mph? What is the speed relative to ground? You could do that in your head but draw the picture and the vectors. You add the vectors to get a resultant vector which is the velocity relative to the ground.
Suppose the plane again heads north at 100mph but there is a wind from the east at 100 mph. Add the vectors to get the resultant. The plane in this case travels north west at a speed of sqrt(2)*100
Still confused? Is your textbook of little help, see:
http://www.physicsclassroom.com/class/vectors/u3l1f.cfm
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
