What are the Polar Coordinates and Speed of a Car on a Straight Road?
A car travels at a constant speed of 65 mi/hr along a straight road, with an angle of 60 degrees at a certain instant. The problem involves calculating the radial and angular speeds, Vr and Vtheta, using polar coordinates. The user initially miscalculated the radius, assuming it to be 100 ft, which led to errors in their calculations. After realizing the mistake regarding the radius, they sought clarification on the correct position of the car relative to the origin and its direction of movement. The discussion highlights the importance of accurately defining parameters in physics problems.
krnhseya
A car P travles along a straight road with a constant speed v = 65mi/hr. At the instant when the angle theta = 60 degrees, determine the values of r (with dot above) in ft/sec and theta (with dot above) in deg/sec. (r = 100ft)
The picture has a car on highway and radius pointing diagonally from the origin which is on the field in "/" like this.
Vr = r (with dot above)
Vtheta = r*theta(with dot above)
v = sqrt(((Vr)^2)+((Vtheta)^2))
Vr = v cos theta and found Vr without a problem.
I tried to plug in v = 65mi/hr (converted to ft/sec) into 3rd eqn with Vr in order to find Vtheta. After that I substitude it into 2nd eqn since I know the radius. I got the theta value and converted to deg/sec from rad/sec but I am not getting answer.
What mistake have I made? :(
Thank you.
What is the position of the car relative to the origin, and what direction is it moving in?
wow, i just made the stupidest mistake ever...
i JUST realized that radius is NOT 100 hahaha
sorry about that! and thank you!
