Poteintial difference to move mass
  • Thread starter Thread starter indigojoker
    Difference Mass
The discussion revolves around calculating the potential difference required to tilt two parallel plates at a 20-degree angle with a charged sphere suspended between them. The initial approach involves using the force balance equation F=QE=mg sin θ, leading to an expression for electric field E. The potential difference V is derived from integrating the electric field across the distance L between the plates. Clarifications indicate that the minus sign in the potential difference is not significant, and a free body diagram is suggested to better understand the forces acting on the sphere. Ultimately, the correct formula for potential difference is V = mgL tan(20)/q.
indigojoker
There's a small sphere of mass m that hangs by a thread. the sphere is between two parallel plates L apart. The sphere has a charge Q. What is the potential difference that will make the plates to assume an angel of 20 degrees with the vertical?
F=QE=mg \sin \theta
E=\frac{mg \sin 20}{Q}
V= - \int _0 ^L \frac{mg \sin 20}{Q}dx
V= - \frac{mgL \sin 20}{Q}d
i feel like this question should involve more work. was my thought process correct?
Yes, it's correct. (But the d in your last line is presumably a typo.) Also, since the question asks for "potential difference", the minus sign is not really relevant.
yes it's a typo
could you explain why the potential difference is not relevant?
F=QE=mg \sin \theta
How do you get the first statement? Do a free body diagram of the forces on the suspended mass. There is the tension in the string, gravity and the electric force. From a free body vector diagram you should be able to get the expression for E and then V (=E/L) .
AM
If you do the free body diagram you will see that the gravitational and electric forces have to be balanced by the tension in the string.
\vec{T} = q\vec{E} + m\vec{g}
This means that:
T\sin{20} = qE
T\cos{20} = mg
Dividing:
qE/mg = \tan{20}
EL = V, so
V = mgL \tan{20}/q
AM
